Had a bit of a search around but couldn't find any relevant information on the subject. Old ea82 has been a little bit rough at idle lately and I put it down mostly to needing a few new parts like rotor button, disty cap, leads and plugs. Both my cars need this so I figured Id do them both at the same time but until I get the parts in I might just clean the crud off of the cap and rotor contacts. Opened it up and here's what I found,
can see where the rotor has been rubbing on this sensors plastic cover.
Either something as fallen into the reluctor or the sensor has come loose and moved into it, but I didn't see any damage on the pickups.
Now this one is the most confusing for me, I hope someone can shed some light onto it. I noticed that if I grabbed the rotor and rotated it, it moved upwards on the drive gear. This movement came from here,
SO I filed the reluctor star back into shape, disassembled everything, cleaned and lubed it and put it back together, but I thought Id ask if this is normal?
To me It kind of looks like there's meant to be a ball bearing under the disty shaft as it has a divot in the head and in the end of the shaft.
Any opinions would be grateful.
Doug
