http://www.skylinesaustralia.com/forums ... il-filter/
The rubber seal leaking (minor but annoying) but much more worryingly, an engine knock on startup. Mine did both! Apparently the engine knock is something to do with it building up oil pressure. It will be interesting to see if I get the knock again.
Other than that they seem to do a good job at filtering. From what I read, most filters do a good job of filtering down to 20 microns but metal particles from 5-20 microns also damage the engine. Filters cant be designed to filter these out as the ultra fine filter surface would reduce oil pressure damaging the engine. The magnet in the filter attracts these, so you get the best of both worlds.
Another thing I like about the Drift, apart from the metallic blue finish lol, is it has a very handy nut on the bottom to untighten with
![Image](http://ozfoz.com/forum/images/smilies/icon_mrgreen.gif)
But the engine knock & that thread really makes me hesitant about using the Drift again
![Image](http://ozfoz.com/forum/images/smilies/icon_e_sad.gif)
So what do others use? What should I be using? Ryco, genuine, etc...
Anyone have a link to bulk buys?
