The Redarc controller and wiring specs below
SPECIFICATIONS
MODEL BCDC1240
DIMENSIONS = 120mm long x 150mm wide x 37mm high
WEIGHT = 680 grams
INPUT VOLTAGE RANGE = 9 - 32 volts (this means suitable for 12 and 24 volt systems)
CHARGING SPECS = GEL /AGM BATTERIES 14.5v (max) 13.3v (float)
= STANDARD LEAD ACID BATTERIES = 14.9v (max) 13.3v (float)
= CALCIUM TYPE BATTERIES= 15.3v (max) 13.3v (float)
OUTPUT POWER = 40 amps (max) 600w (max)
INCLUDES
1 x Genuine Redarc BCDC1240 with installation instructions
2 x 50 Amp Circuit Breakers ( more expensive but in our opinion better than fuses )
6m x 8 B&S Genuine Tycab Twin Sheathed Cable
2 x Yellow Joiner Terminals
4 x Brass 6mm Cable Lugs Nickle Coated
2 x Brass 8mm Cable Lugs Nickle Coated
2 x Nickel Coated Brass Marine Battery Terminals
CABLE SPECIFICATIONS
7.71 mm squared Nominal Area
stranding 96/0.32
Weight 558 grams (app) per 6 metres
74 amp rated @ 30 degrees ambient temperature
The front and rear anderson plugs will each be connecting to a 100w flexible monocrystaline solar panel, (200w total).
WayneO...................
