Subaru l series oil in my air intake/filter
So I had my wagon down a creek bed today testing her out. I had the front right down in a hole and the rear left right up in the air so I got out to get a few photos and left it running then I drove out And I noticed a big trail of oil! It was coming out the air box, hasn't done it before that I know of :/ I'm just wondering what causes this and how I can stop it in the future
How much oil was in the engine? and how much is left in it now? Remember you can only get a true reading on the dipstick first thing in the morning. I find so many Subaru engines have been over filled because they have been checked just after the engine has been turned off.
Another big factory in oil in the air filter tray is due to the air filter being dirty and it gets sucked up through the breather pipes.
And a plus 1 for what TOONGA said about turning the engine off
I'd do as TOONGA has mention and fit yourself a catch can. You can buy them of Supacrapy for $40
You'll just need to empty this out ever so often. I'd also look at the air filter intake, as there is a little summer/winter flat on there and this might be getting stuck in the winter position, this could be restricking the air into the housing and cause the engine to draw the air from the breathers?? Also make sure the little rubber flapper do-dads on the back of the air filter housing aren't blocked off.
Sorry didn't know yours is a EFI version and I didn't askStrevdog wrote:Mine is the mpfi ea82 will it still have this little flappy things in the intake pipes? I didn't see them when I was cleaning the oil out of them?
I wouldn't block your PCV but maybe try putting your breathers into a couple of plastic bottles and go for a good hard drive, then have a look at the bottles and see how much oil is in them.Strevdog wrote:And can I block the PVC valve pipes off for now? The pipes that go from the rocker cover into the air intake? That's where the oils coming from
PCV= positive crankcase ventilation, so if you have blow-by your crankcase pressure will be higher, pushing more oil out the pipes. If you block off the pipes then I'd imagine other things might happen as the pressure builds up like blowing seals & gaskets
Sounds like a catch can is your best bet till you find the cause
Can you do a compression test?
Yes, Yes, Yes any you answered the last one yourselfStrevdog wrote:Would bad blow buy make my engine run rough all the time, loss of power and shooting oil up regularly not just every now and then? And what would fix the blow buy issue? Rebuild?
I'd try a compression test first, before you go too far
