Are the injectors in all 3-pin ecu EA82t's the same part number?
I'm planning on getting them out to clean and want to get some new rubber seals.
I also see that the hose seems to be attached fairly firmly - is there a specific procedure for removing them?
thanks
						EA82t injectors
I think the only difference in EA82 injectors was turbo got red ring NA got grey. Was there any non turbo 3 pluggers in L Series ? OK thinking the Royale and Vortex were NA mpfi so could have been 3 plug ecu stuff. Think I read 4 plug ecu injectors ran a different resitance value ??
The rubber seals between injector and manifold can cause some hard to find grief, so good idea. They are a almost universal seal not needd to go genuine, just an injector service agent.
Those hoses, never done one.....
