EA81T rare engine trans for sale
- Tweety
- Silverbullet
- Silverbullet
- subarooster
mmm did see this, its only an hours drive from the oldies place, although i'd only be buying it just to say that i had it, most likely wouldnt have a use for it.
01' Liberty B4.
- Tweety
Not that I'm still interested in boost myself but be interesting comparing output of this with a blow thru supercharger the latter more simplistic in my view with no lag etc.
But its horses for courses I suppose.
A bit over priced really, and the photos taken with a fish eye lens are annoying. Kinda reminds me of 'walleye' off 'Hotshots 1'.
Throw it in ya new wagon Tom, pick up a cheap fuel only ecu off ebay and let the fun begin.
- TOONGA
with a "little modification" the "L" series power steering pump should be able to fit. you would just need to move things around abit on your engineSilverbullet wrote:Looking at it again I dunno how I missed it, it has L series style power steering pump setup! Right next to an A/C compressor! Shame I can't have the same setup
something like a microsquirt, megasquirt or a megajolt. as it has what appears to be the same dizzy and injectors as the MPFI "L" theoretically you could get it to run on a turbo "L" or vortex ECU that runs a similar dizzy.Tweety wrote:Gannon- "Fuel only ECU"...please explain what is involved in this type of unit..sensors etc. never seen one.
Most aftermarket ecu makers offer a fuel only ecu option. Uses basically the same number of sensors but is easier to tune because the ignition is handled by a mech/vac distributor. Common use is on old motors like holden/chev and ford
- Silverbullet
TOONGA wrote:A mate of mine just purchased a whole EA81 turbo car just out of Bunbury for 350 dollars.
He is very happy
- TOONGA
No idea how he got it, I got a text from him saying he found the car and bought it (probably without blinking) They are out there SB, lots of barns down this waySilverbullet wrote:why can't cars like this exist in Adelaide? What a score, did the seller even know what he had? Or was he a mate/family member?
Nope not RSR, a local from Bunbury I know that owns a brumby which I dare say will be getting a lot of work done to it very shortlysteptoe wrote:Same mate that bought the EA81S twin port twin carb rally wagon perhaps ?
Getting a look at it this Friday ... Wait for it!!!! a 1983 full import turbo wagon? with early 5 speed push button 4WD transmission, apparently called an AJ5 ???
WTF me thinks someone built this out of bits
Never knew they existed, even from OS markets.TOONGA wrote:Wait for it!!!! a 1983 full import turbo wagon? with early 5 speed push button 4WD transmission, apparently called an AJ5 ???
$350, body in good nic? I would say if it is keep this thing original, these will hold good value in time to come!
