Could this be my fuel pump?
Hey everyone,
Trouble with the l series and similar to what I have experienced before. Engine running fine when you are on the throttle but as soon as it drops back to idle it cuts out. Keep it above 1000rpm and it is okay but below that and it konks out. Carb has been rebuilt, Checked Pcv? valve, and idle solenoid. All seem okay. Could this be my fuel pump on the way out?
James
James
No worries, that's what we're all here for!jims wrote:Thanks guys,
Yep checked the idle cut solenoid.
You might be onto something there Bennie. Did run the tank low recently. Gave the idle jet a good spray with cleaner and the problem has gone away. Thanks for the advice!
Replace your fuel filters too
