RS will not start
- chubby37
RS will not start
Yesterday she run great all day.parked it last night but I went to start her today and nothing.buy nothing I mean it won't fire.it cranks over nicely but just won't fire????
Thanks bill
Thanks bill
- chubby37
Pump back....tested off car and I know it works....would not work once in car....left car for a while...went back outside and fiddled with the pump plug but still could not hear or feel the pump...turned key and after a couple of splutters she fired up and reved good..turned off and started it 3 more times...WTF??...I bet by tonight or tomorrow it won't work again going on the past couple of days....
No there is no sensor to stop the fuel pump if the timing is incorrect that I know of, dodgy fuel pump relay more likely? Check your fuse box that holds the relays and swap the fuel pump relay for an identical relay if there is one, one that you know works, if this fixes the problem, you should have issues on whatever the other relay controls.
- vincentvega
- vincentvega
dunno about one or two wires live at th pump or anywhere between the ECU/fuel pump relay and the pump.chubby37 wrote:Oh ok....the plug at the tank...should there be 1 or 2 wire go live when the key is on?
There is something in your timing - the ECU only gives the power up - might switch the earth wire don't forget if the pos wire always has pos power with ignition on. The ECU makes the connectin for only three or four seconds on initial ign on, then off, until it knows engine is running reconnects again.
Test both neg and positive.
I have powered up fuel pump directly from small sealed lead acid battery, same type connector, from under car in order to keep pos and neg switched, to bang it into life, reconnect the ecu control plug and off I went
![Smile :)](./images/smilies/icon_smile.gif)
