Flasher unit location + photo (L-series)
tambox
Post by tambox » Thu Feb 21, 2013 7:44 pm
Religion, and Subarus have many variances, here's another to have faith in.
L serious, still.
Post by steptoe » Thu Feb 21, 2013 8:54 pm
I am of no use to you, mine is an 85 with it inside the combination ticker/switch - had me stumped can tell you
Dann
Post by Dann » Thu Feb 21, 2013 10:20 pm
haha ok now that a diagram i can relate too, ok ill have a look at that tomoz, if its not the fuse and not the reply what else could it be???
Dann
Looking for:
- LSD diff
Post by Gannon » Fri Feb 22, 2013 5:26 am
steptoe wrote:I am of no use to you, mine is an 85 with it inside the combination ticker/switch - had me stumped can tell you
Yeah that surprised me too when I was trying to get the blinkers working on the RX.
Post by steptoe » Fri Feb 22, 2013 7:27 am
Dann wrote: if its not the fuse and not the reply what else could it be???
Well, if you fall for same thing I did,, I found power supply problems after my fusible link corrosion caused a nice voltage spike or surge - disabled everything for three weeks - did not kill the ECU, so I bypassed wires here there and bloody everywhere to eventually find the indicator bulbs had blown to the extent of shooting the filament to the inside of the glass and fusing to it - all of them coz I used the hazards while in limp mode to parents place - just got there and died. As I replaced the bulbs the flicker rate went from a constant bzzzzzz inside combo switch to a final ticker, ticker noise I desired at the end of four bulbs. Stupid me was pulling the reverse bulbs and finding they were OK , thinking they were indicator bulbs :oops:
Dann
Post by Dann » Fri Feb 22, 2013 7:33 pm
haha hopefully thats not the case, all my globes are good and working, i'll be pulling apart the dash yet again tomoz, as i didnt have time today and hopefully replace the relay and it work, worst cause i'll start crying haha jokes
Dann
Looking for:
- LSD diff
Dann
Post by Dann » Sun Mar 03, 2013 9:38 pm
so eventually got around to changing the relay that i got from the auto store, the guy said that it would do the same thing as the original. I replaced the relay and... still nor working, checked all the fuses and globes again all good, so could it maybe be the switches the hazard switch and the indicator lever???
Heres the nice burnt hole in the old flicker unit and the new one I got given...
Dann
Looking for:
- LSD diff
Post by Gannon » Sun Mar 03, 2013 10:25 pm
Ya know there are 2 types of flasher can, it relates to the pin polarity
Dann
Post by Dann » Sun Mar 03, 2013 11:55 pm
oh really? can you please explain?? how can i tell???
Thank you for any info
Dann
Looking for:
- LSD diff
