12V Air Compressor
mines a slighlty modified 12volt that my grandad had hidden away. i dont use it for 4wd tires but reasonable for the rally car.
ill do a thread on modifying one later when i start pulling another ive got apart
pickstock racing fabrication
pickstock racing photography
GETDIRTYCLOTHING
GETDIRTYCLOTHING
Anyone used one of these? My Super Crap Auto compressor actually deflated my tyre after only the 3rd use. Couldnt even supply enough pressure to keep it inflated!akpv wrote:Bumping this up. I got one of the ebay 12V 150L/min jobbies from ebay user princess trade.
http://www.ebay.com.au/itm/Brand-NEW-15 ... 1e6a4c138a
So I'm on the lookout for a new compressor but I'm on a tight budget...certainly under $100.
- vincentvega
OK, I'm leaning towards spending a little extra to get something that wont let me down in the field. I've found these:
Kinchrome 12V 72lpm 150PSI
Terrain Tamer 85lpm 150PSI
Mishto 12V 160lpm 150PSI
The Kinchrome would be my choice but its only 72lpm, the Mishto is an unknown brand but looks good & is 160lpm.
They're all $110-120.
What do others think? Any other suggestions? Budget is now under $150-
- d_generate
I'd go the Kinchrome for the Aus wide warranty and the fact that they use stainless valves, the plastic reid valve is usually all that gives way on these things.
Mine probably lasted about 6 outings before it died and it still sounds perfectly healthy, it just won't pump pressure, also the carry bag on that one is way better than the massive injected plastic case that most come with.
