gearbox swaps
mistergTrx
gearbox swaps
Post by mistergTrx » Sat Feb 02, 2013 12:31 pm
hi all, just wondering what gearbox i can swap with an auto from a 1997 liberty
the gearbox has TA102AHCAA--DF and havent been able to find one to replace with
its for my partners car and she can only drive auto
thank you
Post by Gannon » Sat Feb 02, 2013 12:44 pm
Generally any auto from a Gen 2 Liberty (1994-1998, BD or BG chassis) should do the trick, as long as its the same ratio, 3.9 for FWD, 4.111 for AWD, 4.444 for Outback
edit:
A quick Google search reveals its from a 2.2L FWD Libetry, so should be a 3.9 ratio
But can you post your VIN number that is stamped on the firewall above the brake booster, or off your rego label?
This should do the trick www.ebay.com.au/itm/2WD-AUTO-TRANSMISSI ... -1997-1998
Post by TOONGA » Sat Feb 02, 2013 12:45 pm
http://www.ebay.com.au/itm/2WD-AUTO-TRA ... 256dd29ed7
was the only auto box I could find, it is 2WD. you may want to try sunspares as they are in QLD as well.
mistergTrx
Post by mistergTrx » Sat Feb 02, 2013 3:48 pm
thanks for your help guys, i'll check them out :-)
Post by AlpineRaven » Sun Feb 10, 2013 8:10 am
Gannon wrote:Generally any auto from a Gen 2 Liberty (1994-1998, BD or BG chassis) should do the trick, as long as its the same ratio, 3.9 for FWD, 4.111 for AWD, 4.444 for Outback
edit:
Can I point out... the ratios are incorrect, it should be 3.7:1 in FWD and AWD manuals. 4.11 for automatics, Outback had 3.7 - US Turbo Outback are 4.44 & Turbo Liberty/Legacy also had 4.44).
Basically you can straight swap the gearbox from any other automatics between Gen 2 years.
CHeers
Post by Gannon » Sun Feb 10, 2013 8:44 am
I was referring to automatic models only. Those ratios were from a FSM and I know auto Outbacks are 4.444 because I have a rear diff in pieces in my shed
