MY89 RXII 3dr
Do a search on discopotato03's threads. He put a spider manifold into his RX and I think it involved rotating the throttlebody.
If you car was an 88 or 89 touring wagon it would be much easier because of the way the later 4 plug ecu is wired
LHD cars have a cross flow AC core, not a reverse flow like us. The condensor/dryer sits on the bracket that holds the EFI airbox.El_Freddo wrote:I've only just noticed this photo - have you got AC with those fans fitted as well? I'm keen to know as I may do the same thing with my L rather than having a very tight fit with the fans behind the radiator.
Love your coupe, keep up the great work! I'd love to have an RXII!!
Unfortunately for them, it also means that there is a fixed (ie aluminium) A/C pipe running across the firewall just above the gearbox. Just ripe to get crushed when pulling an engine.
Current rides:
JDM GTII Touring wagon
Previous rides:
96 Toyota Caldina wagon
:???:Previous rides:
I said rotate the throttle body, not reverse the manifold.
The issue is that the 3 plug ecu has its idle switch on the accelerator pedal and a throttle switch that activates at half throttle whereas the 4 plug system has an idle switch and a potentiometer on the throttlebody.
I guess you could use a voltage sensitive switch to convert the throttle position sensor signal to just a relay that activates at half throttle, it would save swapping throttle bodies
Throttle body was turned 180deg because of the way the linkage operated.
Also, the plug for the TPS was different like mentioned above. I believe I had to remove the wires from my original 4 wire plug to fit the 3 wire plug. This was a few years ago so I cant recall what I did exactly. At my age, its hard enough to remember what I ate for breakfast
My a/c condenser is in the original location (in front of rad), thats why the fans are up front.
I didnt cut the rad support in order to install the Legacy Turbo rad, so tolerances are very tight between engine and rad.
Also, seeing how I have a cold air intake, I have plenty of room for the drier.
Never had a issue with pinching the a/c line that runs along the back either.
Guess I'm not sloppy
And a fairly recent pic for you all to drool over...
drooooooolllllll
Love the way you can fit the spotties into the turn signal area on your bumpers.
No chance of doing that here.
Been trying to source some of the US spec front side markers, cos they don't have the raised turn signal part. Had no luck so far...
Current rides:
Previous rides:
HOLLY SNAPPING DUCK CRAP BATMAN !!! this car is sweeeeeeeeeeet
You are one lucky dude
Can I see pics of under the hood?
I might be able to come up with a pair if your interested.wagonist wrote:drooooooolllllll
ANd the turn signals are now LED's in the corner lights.
I need to take some updated pics, its been a while.RSR 555 wrote:HOLLY SNAPPING DUCK CRAP BATMAN !!! this car is sweeeeeeeeeeet![]()
You are one lucky dudeCan I see pics of under the hood?
But I'll post what I have.
Perrin turbo heat sheld.
I detailed the engine and all the attachments before the install.
Before...
After...
Damn!!!Turbone wrote:Since you mentioned corner lights, this is something I'm working on.
more goodness
Did the amber sections originally have globes in them? Or are they just reflectors?
If globes, just make me a set of those
Now, if I can just figure out how to make a set of wagon taillights clear....
Current rides:
Previous rides:
Thanks for these pics and EJ22T SOHC is the bomb.. you lucky bugger you
