I discovered them as I removed the rear bench first on the touring wagon
then I noticed I have the exact same plumbing in my L Series.
There are 4 lines running along the floor, inside the cab,
under the middle bench seat that then bend and run along the passenger side floor.
More specifically, three lines run through one common bulkhead
and there's a smaller fourth one running beside it.
Does this mean my L Series has return fuel lines already installed?
Is my fuel pump electrical, or compatible with the EA82 MPFI engine?
I'd like to swap in the MPFI out of the touring wagon into my L Series which is carby EA82.
If my suspicions are correct, I can just find the return line and connect the MPFI engine.
Thanks
