Air-con fuse hunting MY Wagon
- GunFactory
Hi all,
I went on the hunt for the fuse under the dash for the aircon.... just went in blind and this is all I could find... any idea what it is? and where the fuse normally is?
Drove through sydney at 1pm Saturday - so damn hot - that spurred my hunt for working air con.
[ATTACH]3717[/ATTACH]
[ATTACH]3718[/ATTACH]
[ATTACH]3719[/ATTACH]
I found it on the Aircon switch behind the climate control panel..
Cheers.
Cheers.
- photo 3.jpg (35.53 KiB) Viewed 2042 times
- photo 2.jpg (46.82 KiB) Viewed 2041 times
- photo 1.jpg (47.03 KiB) Viewed 2042 times
- GunFactory
AS the ac is an optional extra on most MYs, you will find there is a fuse connected to the +ve lead of the battery.
Then there are pressure switches, either one or two, depending on the system. These will stop it from working if there is not enough gas pressure or to much gas pressure.
Usually there is one located near/on the receiver/dryer (black, looks like a stubbie connected to your ac pipes, behind/on LHS strut tower).
If it is not the fuse,unplug, then short out the contacts on the loom to the rec/dryer.
If it works then you have a gas problem.
- GunFactory
Ok found one fuse under dash near bonnet release lever - white wire
Cheers Niterida
Another off the positive lead of the battery - 15Amp broke it too...
Also Tambox - this reminds me that when I visited my mechanic he shorted it out, power to the condenser or whatever it is and the aircon clutch kicked in.. so maybe that points to the gas hey!
Thanks for the help!!
Cheers Niterida
