Fuel Pump? 1983 Touring wagon EA81
- GunFactory
Hey,
I'm having dramas with my wagon of what I think are the fuel variety.
After driving if the car is switched off, fuel seems to drain away from the carbie and the car wont start for a bit.. after pulling off lines from what I thought was the vapour separator and putt them back on sometimes the car would start and run again with no problems. Below is a pic of what I was pulling lines off - I now think this is the fuel pump, anyone car to fill me in?
[ATTACH]3677[/ATTACH]
[ATTACH]3678[/ATTACH]
[ATTACH]3679[/ATTACH]
This component definitely makes pumping sounds...
- photo 3-1.jpg (37.98 KiB) Viewed 3897 times
- photo 2-1.jpg (43.27 KiB) Viewed 3897 times
- photo 1-1.jpg (39.39 KiB) Viewed 3897 times
- GunFactory
Right, I'm almost sure that the pump is failing, not pumping fuel to carbie...
Unplugging and replugging the power supply to the pump got the unit to make pump like noises and vibrate, but only for a second.
Has anyone got any tips on where to get a new pump? Is there a generic pump that I could replace this one with>?
- thunder039
- GunFactory
- GunFactory
- GunFactory
- GunFactory
Under the hood, just behind the passenger side suspension strut top - It had me confused for a while - I had no idea what it was for a while, thought it was a vapour filter.kodez23 wrote:is that fuel pump located under the hood or up the back near the fuel tank?
The new pump is so noisy - the mechanic warned me... I didn't believe him - but shit. haha at least I know the thing is working I guess.
- GunFactory
I took my fuel line off at the pump a couple of time when the problem arose to see if any fuel was getting through, sometimes it would pump sometimes it wouldn't, but with mine you could put your hand on the pump and feel it working (or not working) - I checked it out with a test light and there was definitely power getting to it and unplugging an re-pluging the power supply to the pump would get it making noises.
my problem was intermittent, the car drove well when it did start etc so just took the plunge and got the new pump as I needed it on the road ASAP. If your not in such a rush you could pick up one of the pumps that were linked on page 1? looked like good prices!
- GunFactory
I had a helper, but I disconnected the fuel line which came off the pump and went to the carbie and held it into a empty container while a friend cranked the engine over a few times, on some occasions fuel would flow, others nothing.kodez23 wrote:Yeah the fuel pump seems to be working, I can hear it, although I haven't actually checked the flow (whats the best way of doing that?). I put new fuel filters in today..same prob, starts then konks out in 10 seconds or so.
I'm only new to these cars and mechanical stuff in general so i'm not entirely sure how to undertake further diagnosis.
