i wonder if its also just australia that is having the problemsSubyroo wrote:You would expect this type of problem to also arise during testing of the prototypes and modifications made before release, is Subaru quality control slipping down the gurgler?
2010 Diesel Drivetrain shudder
- thunder039
2004 subaru forester -gone
1999 subaru forester- no more
1989 subaru brumby- sold!
2008 zook jimny -sold!
- TOONGA
We have a 2010 TD forester and it has never had the shudder of unhappyness. mind you from the outset my wife has driven long distances and never used enviro-diesel.
I even asked the dealership in Bunbury about this shudder, they said they have been briefed but have not seen the problem ... ("yet" could I add)
As for the problem in other countries
http://www.subaruforester.org/vbulletin ... post7.html
from this thread http://www.subaruforester.org/vbulletin ... tc-110745/
so it could be a problem world wide
Skipalami, are you calling the soot accumulation ratio "DPF unburnables"? I had my 75000Km service today. The soot accumulation ratio was at 2% (12% last service), but the cumulative ash ratio was at 26% (21% last service). Guess that means my DPF is 26% blocked.skipalami wrote:Outback's 62500km service just completed. DPF unburnables at 4%. Was the same at 50000km service as well.
Dan
07/2010 Forester 2.0D Premium
1979 Toyota BJ40 Landcruiser (Old-school diesel! )
)- greydiesel
Just to follow up on this thread, i've had the EGR valve blanked off since February and the engine has not made a single shudder in that time.
It's %100 EGR system *related*. Right after blanking the unit, the engine still shuddered in an identical fashion. But, with after an ECU reset, the problem hasn't reappeared.
It's possible a learned function gets disrupted because of the EGR's operation. Just looking at it logically suggests the EGR valve operating causes the ECU to learn parameters which lead to outputs that cause the engine to shudder.
In summary, the car had a shudder problem for 14 months until the EGR was blanked off and the ECU reset. It has been working well for 9 months. DPF still re-generates and the car drives fine. Economy is better.
The engine check light does come on every 1000-1500kms with an intake temp error, which is common when EGR's are deleted. Looking into an electronic fix when i get some time.
Oops, I forgot...24%[email protected] (max 100%ash=~260k)
2010 Forester Diesel 62.5k service ~7 Nov: DPF Ash level readout 24%.pitrack_1 wrote:That's encouraging, I'm up for the 62.5k service next, probably near the end of the year. I'll see if I can get a readout too.
Spoke to the service manager. He didn't know about the ash level readout at first, but he bothered to find out (unlike some others). Willing to talk about other issues, he was most helpful and after my query upon possible eventual replacement due to ash he rang the Subaru Aust engineers to determine when the DPF replacement warning would be tripped.
The answer is DPF ash warning is at 100% ash level. So assuming linearity that gives me 62.5/24*100= ~260k kms before DPF replacement.
He also mentioned several DPFs have been replaced due to petrol being inadvertently added to the tank, they are $$$$ so be careful refueling!
Patrick
Ex- 2010 Forester Diesel
I was reading about the Mazda C5 Diesel and it's problems last night, looks like Subaru are not alone with diesel issues.pitrack_1 wrote:2010 Forester Diesel 62.5k service ~7 Nov: DPF Ash level readout 24%.
Peter
But if it's the dipstick issue there's actually little to worry about, apart from owners whining about checking the oil level every 1000kms.Subyroo wrote:I was reading about the Mazda C5 Diesel and it's problems last night, looks like Subaru are not alone with diesel issues.
Patrick
Pitrack, have you seen this claim yet?
									Hi guys, we've got some news for the the diesel guys.
When I teamed up with a couple of Euro tuners, I pushed for the diesel forester tuning side of things.
The end result is we've managed to disable the particle filter sections in the ecu and also gain a bit of performance.
Our 'disable' DPF functions are cheap but they also require you make a booking with an exhaust shop to physically remove the particle filter. You can drive around with a clogged PF for a some time, but you will have to remove it eventually.
On top of this, we can tweak the ECU and gain around ~30hp and ~90nm of torque over the stock ecu base map. This can be included or be a separate tuning process.
If you want to know more, just ask away... Cheers
_________________
Tip for modding: Pick 2 from below:
FAST, CHEAP, RELIABLE...
www.crispmods.com or Visit my EBAY store for a quick look at some products
Peter
Hmmm, funny you should mention that. Are you tracking me, Peter?Subyroo wrote:Pitrack, have you seen this claim yet?
 I was at MRT today having a gander at Brett Middleton's Diesel Forester which won the SUV Challenge (albeit a category started by him), and it won't have done that undergoing DPF regens.
 I was at MRT today having a gander at Brett Middleton's Diesel Forester which won the SUV Challenge (albeit a category started by him), and it won't have done that undergoing DPF regens.Interestingly, the thing is almost bog standard, apart from safety mods, some suspension, tyres and an ECU retune +reprogram. Same intercooler, exhaust, radiator, EGR valve(!) et al.
Oh, and I did see crispmods somewhere, sometime. Note though the word seems to be the standard dual-mass clutch +flywheel can't handle more than ~400Nm (and +90Nm would give 440Nm).
I'd suggest the comment at the bottom of their post is telling...
Cheers,Tip for modding: Pick 2 from below:
Patrick.
Patrick
Hey People,
This post may scare people a bit so don't read of you are the anxious type.
We got one of the first diesel Foresters (early 2010) and have had all these problems: shudders, DPF lights etc and others. Combine this with a useless local service group and our first experience with Suby is not a good one.
But it gets worse! Our car has 75k on it and recently has had numerous DPF light issues and shuddering has got worse but the other day the engine literally exploded: no I mean really exploded with a huge BANG and then died. It's under warranty .... just under thank god ... we had it towed the extra 100kms to a dealer much further away. Anyway it turns out that the turbo had exploded taking numerous other components with it (header pipe etc). We were told that the turbo was not getting any/enough oil but dont know why yet!
But on reading about oil dilution I am wondering if this is the real issue here: I understand oil dilution in diesels as I have always had diesels (mechanicals -> Euro V) but do not understand the link between DPF regeneration and oil dilution???
Regeneration takes place by pumping diesel into the catalytic converter to burn to heat it up (the converter glows red hot in our Isuzu trucks!!) but I don't understand why this should affect the oil dilution levels ??? Or have I missed the point: does the DPF light serve a double purpose i.e. DPF issues AND warning about oil change intervals AND/OR dilution levels???
EDIT:
Note 1: Oil dilution ocurrs because in cars diesel is injected during the exhaust stroke and thence into the exhaust/turbo and then to converter. Truck engines tend to inject the diesel directly into the catalytic converter. During the next compression stroke the left over diesel oil is forced past the rings into the oil/sump thus diluting it.
Note 2: Yes the DPF light is more like a generic warning light and so servers many functions including DPF and oil dilution (the latter via a simple "if regens_since_last_oil_change > x then DPF light->on)
EDIT:
You may not actually need to do all the stuff they say in the article.
The DPF just uses simple pressure sensor comparison to read the pressure difference between front and rear of the filter. The pressure sensors are physical devices with an electrical output: you just have to simulate the output. In the case of one common light truck a simple 18k resistor between the terminals of the sensor comparator works fine; you can even disconnect the sensors altogether. Most DPFs also have a temperature sensor as well but that can just be left in place as well; the dpfs are almost always stainless so the muffler will last forever but you will have to remove the filling as per the article.
If you want to do this mod you will need a multimeter to measure the voltage at the two terminals of the sensors and the current to work out the resistor. Most circuits are quite simple if the comparator is not in the computer itself:
If individual sensor voltages are sent to the computer you will need to make two adjustable voltage regulators (zeners would probably do) to simulate "normal" sensor outputs.
HOWEVER NOTE: that the process of disabling/removing the DPF is illegal in all states in AU so your repair job will have to look "original" if you go over the pits.
Code: Select all
front sensor ----comparator------rear sensor
                [color="red"] |       |[/color]
                 Va     Vb
R = (Va-Vb)/I
New circuit
Va ------ R ------ Vb
Time to take action
Hi all, as with many of you im fed up with dpf and oil dilution issues and the lack of action from subaru. Im going to lodge a complaint with fair trading. Would love to receive any pm's from anyone that would like to jump on board or forward me their specific issues to include as evidence. If this has limited/no results I will be taking legal action. There is definitely a case here these issues are not acceptable.
						So a couple of years down the track now, are diesel owners still having shuddering issues? I am keen to pick up one of these second hand usually with around 150k on them. While I am happy enough to work with DPF and oil dilution issues, was there ever a solution/diagnosis to shuddering (yes I read the while thread). EGR delete?
						No shudder for several years, nor have heard of anyone else having it in the past few years either.LTurbo wrote:So a couple of years down the track now, are diesel owners still having shuddering issues? I am keen to pick up one of these second hand usually with around 150k on them. While I am happy enough to work with DPF and oil dilution issues, was there ever a solution/diagnosis to shuddering (yes I read the while thread). EGR delete?
I'd give a qualified 'solved' to this, at a guess from some software update.
Aim to pick up a newer one, say 2011/2 +, (whichever had the engine update). There seem to have been less issues with the newer ones- at least less posts/queries.
Look out for the glow plug issue with the 2010 (see my posts -and others- elsewhere), also search on this forum, such as here, blown turbo hoses, thrown A/C compressor.
Note shorted glow plugs blow a fuse that also disables the ABS and hence all stability control functions...and cruise control to boot.
Patrick
Thanks for the advice and links Pitrack. Yeah, I have seen the glow plug issues through reading this thread and others.pitrack_1 wrote:No shudder for several years, nor have heard of anyone else having it in the past few years either.
