Been having a little trouble with my subi and torque bind.
At first i figured its the cv shafts in the front so i have replacements ready to fit this weekend.
Upon inspection theres no splits in the boots however there is grease strewn all over inside the front and rear lh wheels wells.
Next i found a split in the lower knuckle on the LH side
So that will have to be replaced too now
Then i put the car back together and got to researching online and came up with the quick fix and troubleshooting solution of placing in the fwd fuse.. Only theres a problem, theres no wires running into the location where the fuse should be.
Am i missing something here?
