KYB Shocks
Matt
KYB Shocks
Post by Matt » Sun Oct 28, 2012 8:51 pm
Does anyone know the part number for the adjustable KYB L series shocks please?
"Claudia"
Post by RSR 555 » Mon Oct 29, 2012 12:13 am
From what I've found, KYB only made the adjustable ones for Subaru and they were (not available anymore) only available from Subaru Spare Parts.
Cliff R
Post by Cliff R » Mon Oct 29, 2012 4:34 am
These were on the rear only werent they ?
I seem to recall my 88 model L series had them but my 92 model L series doesnt.
Were they only on a certain year model of L series ?
Post by steptoe » Mon Oct 29, 2012 6:30 am
Really only thought they were 85,86 L wagons that got them originally
Post by RSR 555 » Mon Oct 29, 2012 8:41 am
steptoe wrote:Really only thought they were 85,86 L wagons that got them originally
I've only seen them on 85 and 86 models too. I'm sure others have fitted them to later models but never from factory. Of course the MY series had them on the front too but this thread is talking about L.Series ones.
Mitchhsj
Post by Mitchhsj » Mon Oct 29, 2012 4:23 pm
can you get higher springs like from king springs or any similar company for l series, that will go in to stock towers??.. thanks
Cliff R
Post by Cliff R » Mon Oct 29, 2012 5:00 pm
Someone may say different but at least from Auto 1 standard height are the only King Springs now available.
Matt
Post by Matt » Mon Oct 29, 2012 6:20 pm
To answer the questions yes rears... My bad. King springs are able to make custom height springs, rates, etc. However bear in mind that standard height king springs will be stiffer therefore make the car sit higher then normal height.
"Claudia"
Post by El_Freddo » Wed Oct 31, 2012 9:18 pm
Mitchhsj wrote:can you get higher springs like from king springs or any similar company for l series, that will go in to stock towers??.. thanks
For the rear you can't got past the honda front end springs from the early nineties - I've got a set in the back of Ruby Scoo and wished I had have done it much earlier!
About the factory adjustable rear struts for the L series - I thought they were pre '87 too.
Wagonman
Post by Wagonman » Wed Oct 31, 2012 10:46 pm
Hey El Freddo. I got the Honda springs (std) with the KYB strut (+3" lift) and i found out the hard way that if you dont extend your bump stops they snap the spring seat off. I quickly welded some extensions onto the bump stop plate measuring about 10cm high cos i was going on a trip lol.. TOO HIGH! I ran on bump stops the whole way. Perfect ride height when fully loaded tho ;) Anyway, what did you do with yours?
Post by El_Freddo » Sun Nov 04, 2012 2:22 pm
Wagonman wrote:Anyway, what did you do with yours?
Always drive carefully!
I've knocked one off but I carry a spare (now)!
Next trick I'm looking into is air bagging... We'll see how that goes.
Wagonman
Post by Wagonman » Mon Nov 05, 2012 8:07 pm
Yeah i carry a spare too and im probably just going to cut down the bump stops a bit and see how it goes. When i wrecked one of them i ordered two more. it hurt the hip pocket but at least im covered.
M0rpH
Post by M0rpH » Wed Nov 21, 2012 11:48 am
Any chance one or both you fellas could post some pics or start a thread about this?
The rear spring mod was something i was about to have a crack at, but now i am a little dubious after reading the last 2 posts in this thread.
My head is a little hazy right now but i take it the bump stops is the rubber cone on the shock absorber rod?
Or is the bump stop the rubber mount located between the body and the read suspension arm?
Sorry for partial thread hijack.
EDIT: scrolled down a bit and found showthread.php?t=22646
Now have a slightly better idea, though some pics wouldn't go astray ;)
Post by El_Freddo » Thu Nov 22, 2012 1:59 pm
M0rpH wrote:Any chance one or both you fellas could post some pics or start a thread about this?
Already done here. It's buried in the middle of the thread but that's the one that counts!
M0rpH wrote:The rear spring mod was something i was about to have a crack at, but now i am a little dubious after reading the last 2 posts in this thread.
It's up to you. I love it and have changed my driving style. My spring seat failure was due to a dodgy shock not doing what it should have been doing, this allowed more force to act on the spring seat that eventually knocked it off :(
M0rpH wrote:My head is a little hazy right now but i take it the bump stops is the rubber cone on the shock absorber rod?
There are both, but wagonman is talking about the rubber mount located between the body and the swing arm.
Happy reading!
