EJ22 in L series sump mods
tambox
Post by tambox » Sat Oct 06, 2012 7:03 pm
Has anybody modified or fitted a different sump to an EJ22 when it fitted in an L series, as it hangs down a long way.
I have a few dead EJ22 motors and was thinking about doing some mods to increase the clearance.
Any help would be appreciated.
Post by El_Freddo » Wed Oct 17, 2012 3:08 pm
I've wanted to cut down my sump to increase the clearance under it so the bash plate can sit higher. I also want to angle the front edge for a little be of extra clearance on the approach angle.
I might get there some day, it's not an issue at the moment so I've not bothered, plus it means engine out and down time on the car :(
Getting the oil pick up and the baffling correct would be the tricky bit I reckon.
Post by TOONGA » Wed Oct 17, 2012 4:10 pm
look at the vanagon sites for information on this, as these guys have to cut the sump down for clearance issues.
heres one
about half way down that page
Post by El_Freddo » Wed Oct 17, 2012 10:21 pm
TOONGA wrote:look at the vanagon sites for information on this, as these guys have to cut the sump down for clearance issues.
heres one
Bugger me - that fella LIVES out of his van :shock:
No real details, but here's his images I've "borrowed on a permanent basis":
Cast aluminium sump:
Smaller pick up pipe can be seen on the engine:
Finished result:
Also, this thread answers my oil pump question :D If it's reliable!
* 93 - 96 SUBARU IMPREZA 1.8L SOHC
* 90 - 01 SUBARU LEGACY 2.2L SOHC
* 95 - 01 SUBARU IMPREZA 2.2L SOHC
* 91 - 94 SUBARU LEGACY TURBO 2.2L SOHC
* 96 - 99 SUBARU LEGACY 2.5L DOHC
* 98 SUBARU IMPREZA 2.5L DOHC
* 98 SUBARU FORESTER 2.5L DOHC
* 99 - 01 SUBARU FORESTER 2.5L SOHC
* 00 - 06 SUBARU LEGACY 2.5L SOHC
* 99 - 05 SUBARU IMPREZA 2.5L SOHC
* 00 - 06 SUBARU OUTBACK 2.5L SOHC
* 03 - 06 SUBARU BAJA 2.5L SOHC
list of the Subaru oil pumps that are the same as mine.
I got stuck reading what he got up to, didn't get to the end as I should be in bed... but he knows his stuff about these vehicles - even imported a an audi (I think) alpine gearbox or something, flipped the diff, made a bell-housing adaptor plate (bell housing to gearbox) to mate up the subaru EJ22... Then suspension stuff started and I phased out on that thread.
I wonder where these sumps could be found - my issue would be oil starvation when on extreme angles left or right...
tambox
Post by tambox » Thu Oct 18, 2012 7:07 pm
The sump looks great, found out some info about them, they will not fit with Subaru engine mounts, designed to fit VW mounting system.
http://www.rjes.com/html/sumps.html
I have a dead ej22 (need an oil pump Bennie? 360,000km!!), that once I get the EA82 off the engine stand I was going to investigate some custom cutting and welding.
Just looking for Ideas.
Post by El_Freddo » Sun Jul 06, 2014 7:28 pm
How's this going Tambox?
You've been a bit quiet on the forums lately - hopefully this means you've been busy with subaru mods :twisted:
tambox
Post by tambox » Mon Jul 07, 2014 6:08 pm
Not quite Bennie, work kills fun.
I am still very happy with the EJ22 LPG in the L, at this stage I re-shaped the sump gaurd and settled for that.
Have a couple of sumps and have plans to modify one, but still in the "plans" stage.
L serious, still.
Post by steptoe » Mon Jul 07, 2014 7:02 pm
aha ! Another reason not to EJ (says the man who is yet to drive an EJ in an MY or L )
Post by El_Freddo » Mon Jul 07, 2014 9:23 pm
steptoe wrote:aha ! Another reason not to EJ (says the man who is yet to drive an EJ in an MY or L )
Really??
The only reason we're talking about this is for more ground clearance. It's not necessary for a daily runner/road goer. Actually it's not really necessary unless you're trying to gain a little more for potentially a lot of work...
tambox
Post by tambox » Tue Jul 08, 2014 8:55 pm
Its a nice idea to improve the current setup.
This from someone who spends his life improving his current set ups, hey Steptoe.
L serious, still.
Tweety
Post by Tweety » Mon Feb 02, 2015 6:09 am
Would shallow dry sump suffice?
tambox
Post by tambox » Mon Feb 02, 2015 9:38 am
Maybe, but that would be a lot of work.
Debatable if it would be worth it for what you gain.
But with Tweety pretty well sorted and you are looking for something to do ........
L serious, still.
Post by El_Freddo » Wed Feb 04, 2015 8:28 pm
I should look into this again and have something ready for the next time the engine is out. I've got a spare sump on an engine I'm not using at the moment, it shouldn't be hard to dummy it up and go from there.
Anyone know if there's a science to it as I would like to keep a good oil capacity and not have the pump starve while offroading...
