Weber conversion going well..BUT!!!!
- scoobymine
Hi guys,
Just fitting my new weber, with everything going fairly smoothly until i got to the accelerator cable. The weber has the 2nut tightening system for the cable to thread throug a hole, so it meant cutting off the lead mallet shaped end that fitted the old carb. Disaster. As expected the cable flared with no hope of threading it AND there was none left to re cut, an inch too short So it looks like a new cable, one that will thread the hole on the Weber. So comes my question, what the heck do i do. Are there any generic cables, or any without the lead end piece that i could use?
Rick
Rick
- Silverbullet
If you want to replace with the same cable, L series cables are exactly the same (parts dept at local dealer looked at me funny when I said 1981, their parts catalogue doesn't go back that far) I haven't done a weber conversion but where is this hole? if it's in a plate separate form the carbie for the 2 nuts to butt up against, could you file a slot just wide enough for the cable to slip through? Failing that there are plenty of members who have done this conversion who could give some clues.
- Brumby Kid
To all those weber experts.
What are you meant to do for the accelerator cable?
I have heard a rumor that the weber acc is on the opposite side to the hitachi one. True?
Hopefully this will clear done things up once answered.
Cheers Cam
Cheers Cam
- TOONGA
1.Unbolt the throttle lever (where your little mallet shape once lived) from your hitachi carburetor.
2.unbolt the throttle lever on the weber, place in a parts packet in case the hitachi one won't fit (it will)
3.bolt the hitachi one to the weber. make a setup to hold the cable in place and work out where your return spring will live.
hope this helps somewhere on the board is a picture of this done, but of course I can't find it.
of all places I find it on the justy board?
http://subarujusty.proboards.com/index. ... hread=3896
- Mitchhsj
i didn't have any problems with mine i have the weber on my 87 L and now on my 91 L the only issue is sealing that water jacket that is exposed when you remove the standard carboy, i keep making gaskets but they get soggy and leak between the spacing plate and manifold...not to worried tho..
- scoobymine
Hi Brumby Kid and Silver Bullet,
The 2 nut hole thingy is seperate. I think if you filed a slot it would weaken it too much.
Silver bullet, the cable is on the same side as the Hitachi, just does'ny have the "wheel" with the cable slot. There is some Weber cables available in the UK, but the pedal end doesn't have the "mallet shaped" head
- scoobymine
- Mitchhsj
yea i tried blocking it off but needed flooding my motor 4 time before i worked out what is was.. u can't put anything on there [paste] because the fuel will break it down and will leak in no time just got to get some gasket paper and make one up. it comes up and in the little pipe on the passenger side and goes out down the back being part of the cooling system it has something to do with cold starts or cooling for the carb or somthing... bit of a pain.. but be car full with that gasket goo you might get caught out..
- scoobymine
- Tweety
That hole at the base of the manifold neck I tok Steptoes advice when removing my custom manifold and tapped a 12mm thread in it and made up a frub screw with a little thread locak. No more water comes out. Problem solved.
As to accelerator cable too short by an inch try buying 3/32 copper tube from a hobby shop and soldering/crimping it on the cable.
- Silverbullet
This cable isn't the easiest to solder to, I'm not sure what it's made of but the solder doesn't want to stick most of the time.Tweety wrote:That hole at the base of the manifold neck I tok Steptoes advice when removing my custom manifold and tapped a 12mm thread in it and made up a frub screw with a little thread locak. No more water comes out. Problem solved.
I used to make up or repair handbrake cables on my pushies, so instead of chewing out the cast alloy blob on the end I'd just resolder the cable in place on a mild steel rod with 1mm hole I drilled in them. Was surprised just how strong they were taking handbrake force. Maybe 80's pushbike cable will solder better ?
Er, maybe that was 70's cable
