MY Wagon Rust repairs
revmax
Post by revmax » Sat Aug 18, 2012 9:00 pm
Yer I'm hearing you.
Bunnings and Gasweld are pretty close together and are both close to me about 3km by road and I pass them on my way to and from work.
Wanted to do some blasting on the other side of the wagon today but didn't happen because I wanted to get a white guard from B3 but discovered it was rusted out.
I have a red guard origunaly from B1 which is dinted so painted it saturn white from a pressure pack, rough yer I know but the rest of the car is faded so who cares, I just didn't like patchwork pannels.
Sunny looks pretty neat Bennie
Trivia quiz.
How many pressure packs does it take to paint the external surface of a front Brumby/wagon guard.
Brumby Kid
Post by Brumby Kid » Sat Aug 18, 2012 10:28 pm
revmax wrote: Trivia quiz.
How many coats? For one coat to paint the front 1/4 panel it should use less than Hal a can I reckon.
I desperately need an air compressor and a gun, getting sick of pressure pack cans.
Cam
Dads Car: 02 Impreza WRX STi
Post by Silverbullet » Sun Aug 19, 2012 12:45 am
Brumby Kid wrote:How many coats? For one coat to paint the front 1/4 panel it should use less than Hal a can I reckon.
Cam
Nah it must take more than that, I used up 1.5 cans of primer covering up where my old stripes used to be...I'd say little over 2 cans for the guard? I'm just going to bite the bullet and save up for a paint shop to do it :rolleyes:
revmax
Post by revmax » Sun Aug 19, 2012 6:28 am
I used 3/4 of a can but that was all I had, some spots were a little darker so i recon you could get away with 1 can with tree coats. If it was white on white or Beige, one can would be heaps.
Post by TOONGA » Sun Aug 19, 2012 9:19 am
When buying an old bush basher the common consensus was, one can of 3 dollar paint per panel :) and maybe 2 for the roof.
Post by steptoe » Sun Aug 19, 2012 9:46 am
all the same colour or camo varities Jules?
revmax
Post by revmax » Wed Aug 22, 2012 8:48 pm
still plugging away.
should have most done by end of tomorrow except the worst bit, which is the drivers side rear. I blased it on the weekend and it looks like swis cheese.
I am going to have to cut a chunk out and either rebuild it or cut a piece from another wagon and weld it in.
revmax
Post by revmax » Sun Aug 26, 2012 1:45 pm
out with the grinder and some fresh metal.
Post by Silverbullet » Sun Aug 26, 2012 2:15 pm
Sheesh you were right about this thing being rusty :o What section of the car is that exactly? I can't quite make it out from that close in. Looking good!
revmax
Post by revmax » Sun Aug 26, 2012 2:54 pm
in front of the rear wheel drivers side.
revmax
Post by revmax » Sun Aug 26, 2012 8:02 pm
from the other day.
before blasting
after blasting
plate welded over and painted.
revmax
Post by revmax » Tue Aug 28, 2012 5:58 pm
found me camera.
from the outside
still to weld a piece on the inside
Post by El_Freddo » Wed Aug 29, 2012 8:10 pm
Geez, tricky area to be working in!
revmax
Post by revmax » Wed Aug 29, 2012 9:06 pm
yer. I have welded the inside in but it was tricky to line up.
Once lined up it was point, pull the trigger, weave then stop for a few seconds, then start the cycle again. Got it in and it is structualy sound but the high spots had to be ground off the welds.
Have made a template and cut the sheet for the channell support and may get a chance tomorrow to weld and bend it into shape.
