I havnt see the SJR lift ill do some research but i am interested in how much they are worth so far the rear cost me $20 in bolts the c channel was scrap and had some paint sitting around the house so im quiet happy with that
Moderator: Rumbl1n
That should be fine. The difficult part will be stopping your camber adjustment bolts from moving.Rumbl1n wrote:The plate on the top of the strut is 6mm thick
The Radius Plate is the bracket that one end of the Radius Rod attaches to. It attaches to the body with three 10 or 12mm bolts (can't remember which).Not sure what you mean by radius plate spacer
