Brumby pulls to the left
My latest addition a 92 Brumby is pulling to the left.
I replaced an inner TR rack end cause one of them had a bit of slop.
Then got a wheel alignment done.
But she still pulls to the left, it feals like I have done nothing to fix it and just put some money into the car and got noting in return.
The bloke at the steering joint suggested that the top of a strut could be twisting but I don't realy know what he means.
Any suggestions welcome.
Shagged ball joint can hold a position so if you steered to left and starightened up it tries to stick lft. Or, in the MY they have a bush at the top in the top mount is rubber, tight fit on the strut shaft that comes throught it to nut at top under the cap. The rubber can bind on shaft and there are those sintered bronze washers that are designed to work as a bearing to allow turning and back again. L Series actually have a bearing in same spot instead of washers. Soak some CRC or btter Lanotec down in top cap
sounds exactly what may be happening. Have sprayed some silicion spray down the cap, see if it frees up.
- scoobymine
I think so, under hard braking or any braking it tracks straight enough. But I will take more notice next time.
I did have to put SH pads in cause the previous owner had damaged the pads on LHS when the wheel/hub came off, the cause was stripped shaft/nut threads from not doing them up tight and it flogged out. I have fitted the matching pair of pads to the RHS as well.
steptoe do you mean lower ball joints or TRE ball joints.
It does favor a LH pull after a LH turn but is not so predominate after a RH turn.
Thanks Steptoe.
Lower ball joint then. Will try to have a better look IF it ever stops raining. Fark I hate the amout of rain we get.
Yer opted for silicone spray because it may be plastic/rubber
Good point. Point.
That is easy to do, thanks. Yes I have another full set of freshly 2K painted rims and fairly new tyres sitting in the shed.
Might be in Townville early July for work. Would be good to have a look at ya Brumby If I get the chance.
Thanks EJ, she is armstrong steering. No slop/play in the rack mounting
I am confused as I thought the top was fixed and non adjustable.
OH Steptoe I check the ball joints and they apear fine.
AHHH !
now I get it thanks.
Hey Mitch.
Nah no scrubbing but haven't driven it much either.
