A little treat for Brumby lovers
- Brumby Kid
No! Bad boy! No thinking allowed!phantomD wrote:Currently driving a VW Golf GTD which is VERY nice indeed...hmmm...
Don't let your brumby hear that!
If it thinks you don't like it, it's bound to start playing silly buggers.
Cheers Cam
Hahaha I thought that little comment would stir a certain few people
I managed not to overheat it - I pulled over straight away, inspected the aftermath and locked up and called a cab. Normally I would have been able to limp it home as I have an oversize battery, but not with headlights on.
My Brumby knows that I love it dearly however it also knows that I am starting to get a little tired of the EA81 having issues...
- thunder039
but i know what you mean after going from my brumby to my 04 forester i sometimes wonder if i can go back
2004 subaru forester -gone
1999 subaru forester- no more
1989 subaru brumby- sold!
2008 zook jimny -sold!
- thunder039
only if subaru made a current brumby would life decissions just a little easierolddog642 wrote:You can never go back but you can always return
I would dearly love to have a Brumby with auto, powersteering airconditioning and raised 4 inches:twisted:
Hylton
- Brumby Kid
Yes!!!
They should make 3,
What they finished with
A sporty STi model
And a twin cab.
With the option for a turbo diesel.
									They should make 3,
A sporty STi model
And a twin cab.
What sort of issues? Fix them up and she'll be apples for a long time to come with the right maintenance.phantomD wrote:My Brumby knows that I love it dearly however it also knows that I am starting to get a little tired of the EA81 having issues...
Much easier than an EJ conversion IMO!
Yeah I'm going through the cooling system on Sunnie at the moment - I reckon it's all factory gear now with 347k km on the clock. I'm glad I've got on to it before it became a real issue!phantomD wrote:Age-related problems with seals and low kms mainly. Latest problem is coolant leaking out of the water pump and major cold start issues pertaining to (I think) vacuum leaks that are going on in the carby.
- Bertiebrumby
Beaut car, original USB head unit ?
Keep it real. Love the color.
Dunno, call the RTA. But I doubt you'd have any, they wouldn't know it wasn't factory - even then it was from the factory and not an aftermarket accessory.phantomD wrote:If I move to New South Wales, what headaches am I likely to encounter with registration for this car? It'll need an engineer's certificate, right? It has a crapload of modifications such as twin carby engine, rear disc brakes, exhaust, PS/AC and more.
I reckon you'll be fine.
Hi all,
Apologies for being a little silent lately due to various commitments. Just on to post a quick update for my Brumby project.
Attached is a photo of the finished engine going into my car - JDM factory EA81S with dual port heads and twin Hitachi carburettors. The engine is in and has been to the exhaust shop for extractors and a replacement muffler. Tomorrow will be a day to work out the plumbing around the carbies - and if I'm lucky - "start day"!
I owe a major thanks to a friend of mine on this forum (not sure if he wants to be shouted out or not) for rebuilding the engine for me.
Kind regards.
After this point I have decided that I have spent enough money on the car and it is time to look after it and enjoy driving it. The only remaining thing to do is to re-seal the air conditioning compressor and re-gas - anybody have a place they recommend in Sydney?
- I'd like to find a twin carb engine, overhaul it and fit it to the vehicle to preserve low milage of the current EA81 (not even 40 000km...for the moment). If I cannot find one soon then the current EA81 will be doing a LOT of driving. I already have some twin carbs but I'd like the matching engine as well. As a student I can't afford too much but here's hoping that something might work out. DONE
- Replace exhaust system with 2 1/4 inch cat back, possibly from the block if I find a twin carb engine. DONE
- Fit rear discs DONE
- Upgrade lighting - L series interior light, relays for headlights, replace headlights with semi sealed beams. Maybe fit some spotties.
- Fit power steer DONE
- Find 4 wheel caps buying new if possible DONE
- Install electronic rust prevention
- Maybe some audio improvements DONE
- Work on the body some more - I'd like to find some mudflaps (both front and rear) in good condition, passenger door trim, etc.
- Look after it and drive it IN PROGRESS
Kind regards.
				- 1907529_10153136721295020_3231827141047890921_n.jpg (87.37 KiB) Viewed 26585 times
 :twisted:
:twisted:
