Fitting an EJ Motor into an MY or L Series Subaru
- TOONGA
A search on google got me this
showthread.php?p=138712
which got me this
http://www.suberdave.com/USMB/95_Impreza_18l_wiring.pdf
apparently they use the same wiring ???
I don't think so
still looking
L series porn
http://wordpress.suberdave.com/
found these as well
http://www.main.experiencetherave.com/s ... nouts1.jpg
http://www.main.experiencetherave.com/s ... nouts2.jpg
http://www.main.experiencetherave.com/s ... 6specs.jpg
language is Spanish
which got me this
I don't think so
still looking
L series porn
found these as well
language is Spanish
Actually, i think this may only apply to single point fuel injected models.GOD wrote: EJ16s and EJ18s don't have a cam sensor or a knock sensor. Don't think they had any ECU control of the EGR gear either.
- BaronVonChickenPants
Sorry, meant to post this earlier but got distracted by something shiny (*cough* Gran Turismo 5 *cough*)
This is everything I have from when I was doing my EJ18 conversion, I was told the EJ16 was the same also.
FSM Scans
I have most of them in high resolution if you need it.
Jordan.
FSM Scans
Jordan.
Jordan  ! You've moved again?
Thanks guys I shall have a look in time at the links.Hey even my 86 4GLTA ECU 3 plugger has some EGR control, well it is suppose to not operate below a certain temp or work above a certain speed. It does not have these limits - works all the time.
The donk came out of a crashed Impreza 1996 under yella oil cap - got the loom and ECU expertly removed by Damo666 and donated to a good home
Do you really need a DOHC motor? an EJ22 has got plenty of power and a hell of a lot cheaper to buy or even a EJ20.B00sting wrote:Anyone know if you can lift a brumby (93) to avoid chassis rail modification when dropping a DOHC ej25 in?
If so how much is needed?
Have a look at 92 brumby he has only got a SOHC EJ20 in it and it goes well even with 30" tyres.
Jan
[SIGPIC][/SIGPIC]  !!!Subies will go anywhere
						Actually I'd just like an answer to my question if possibleyarney wrote:Do you really need a DOHC motor? an EJ22 has got plenty of power and a hell of a lot cheaper to buy or even a EJ20.
Jan
Does it matter what I want? It doesn't effect anyone else....
Cheers.
-97 Landcruiser
						-97 Landcruiser
Tim (the opening poster of this thread) had a 4" lift in his MY wagon at one point, still needed the rail mod to fit the DOHC motor.
It's only a minor mod, not structural, easy to do and if done well - not obvious to look at. If your heart is set on a DOHC motor, just do it.
EZ30 L series - Monsterwagon
Is it any easier to fit the early ej25s (e.g outback 99) versus the 2006-2010 forester engines?
I can get a 2010 motor for a good price is all.
-97 Landcruiser
						-97 Landcruiser
- Scheffer1986
fitting a ej25 to a 82 my
Has anyone fit a ej253 sohco into a brumby/my wagon ?
						Ideal donor car for EJ conversion?
While pondering an EJ conversion, it dawned on me that there must be an "ideal" donor car for the job, not what is possible, but for example, what would be the best use of the parts available from just one car without cutting chassis rails etc, Forester two litre EJ with manual  D/R g/box, so that I can use drive shafts, diff assy, wheels, brakes, steering column etc.
Is this feasible in just one model?
Am I being overly optimistic in thinking that I could do a drive-line update without having to make major modifications like fitting an EJ25 for example?
My old Brumby that I have on the farm (2 actually) which I am contemplating putting on the road would be a lot more enjoyable if it were for example a EJ20-EJ22 N/A manual D/R gearbox with matching rear diff, drive shafts, upgraded brakes, front suspension?, etc.
What model would give me the best "bang for my buck" if I were to buy just one donor car?
I would think that there would be others who would find this interesting before deciding on an engine/gearbox combo that could need extra parts to be sourced from different models.
- Alpinebarry
Hi guys
New to site and subaru world as such. Just starting my own El22 swap into my ea82 L series. Lookin for all the help I can get
						- TOONGA
El freddos thread about his "L" series would be a good start
showthread.php?t=11733
my thread if you want to go carby and dizzy
showthread.php?t=15851
this PDF will help as well
downloads.php?do=file&id=134
Good luck with it
Good luck with it
- Willy Fisterbottom
