Whats bent!!
- thunder039
cant tell yet because has only happened for the last 2000-1000ks so hasn't had a chance to have a notable wearBusdriver wrote:How is the tyre wearing?
2004 subaru forester -gone
1999 subaru forester- no more
1989 subaru brumby- sold!
2008 zook jimny -sold!
Fair enough - I'm not up with using my phone for internet - that's why I've got a laptop...Alex wrote:yeh, when i replied to this i was on my phone which doesnt show signatures, but it does show avatars, so i assumed it was for a brumby as in his avatar (cant see what car this happened to anyways???)
- thunder039
got back from the mechanics, its either the strut or the strut housing on top that is bent.
there is about 8mm different between the strut and top of wheel between the right and left
don't know weather to try and buy a front top strut brace and push and pull the wheel with the control arm loose then tighten, this will hopefully fix that gap and make it steer more somewhat straight.
or buy a new strut- only issue is if the strut housing is bent this wont help and Ive just wasted a few $$$.
suggestions???
suggestions???
Get a used strut from a wrecked foz. then if that fixes it you know you need to buy a good strut (KYB??) later on.thunder039 wrote:got back from the mechanics, its either the strut or the strut housing on top that is bent.
suggestions???
Then if thats not it you have only wasted a small amount of money
- thunder039
good idea i think i will give that a try thanks!taza wrote:Get a used strut from a wrecked foz. then if that fixes it you know you need to buy a good strut (KYB??) later on.
