Webber troubles
Webber troubles
I have recently had a webber carby put onto my brumby. When i picked it up from the shop they advised me that there is a flat spot, when in first as you initially accelerate ( they put it down as wrong a/m carby). Also i was advised that the carby has two pump inlets but the third was missing??????????? The car drives way worse than before, far less power and it is eating more fuel:mad:.  Please Help.
						Not sure what you mean by "wrong a/m carby"?  What type/model is it?  We need a bit more info. However the shop you took it to would have given you an option/price to fix it no?  Is it genuine weber?
Once you know the problem there is either weber on ebay or a company in Melb called weber performance that will help supply parts and advice.
You only need 1 fuel inlet, and if using the factory pump you don't even need a return line.
A picture says a thousand words, and half a dozen pictures of this setup would be great. It would be interesting to see what they've done with the fuel lines and also the crank case ventilation system.
My weber ran like shit for a while. Took a while to sort out and it was all to do with the ignition components and incorrect timing which, once sorted out, finally allowed the weber to be tuned correctly.
						- Tweety
My brumby engine is a 92 model and in my conversions thread (EA81 into VW trike automatic) someone suggested that no return line to the tank was necessary if you have an electric fuel pump with no more than 3 or 4 psi.
Works great.
									Works great.
						Hi Guys i have tried to attach two photos of the 32/36 dgv Carby, hope it works and i hope it helps.
I took the car to Hervey bay and limped it back home. the Gremlins are still there. While i was on the road i contacted the mechanic and told him he will see the car soon, I then called weber performance and gave them the mechanics Ph.No. so hopefuly they both can figure somthing out??? Thanks again in advance for any insite that you can provide... If the photo's don't work i will try again soon.
				- DSC01449.jpg (110.52 KiB) Viewed 2175 times
				- DSC01448.jpg (115.76 KiB) Viewed 2177 times
- Loyale 2.7 Turbo
The Weber should have just One fuel line attached, my own experience teached me to Not use the Return line and leave the hose open, while the carb's return should be Closed.
Have you checked the Jettings? ...
By reading what you wrote, I'm almost sure that it has one of these issues:
Those should be:
Also, the Choke could be Stuck and not workin' properly.
I Kindly suggest you to Check that and give us Feedback about what did you find, in order to Help you.
Kind Regards.
- Wrong Jettings, or
- Misplaced Jettings.
Those should be:
- Around 120 / 130 \ 140 in Low Stage (Primary)
- Around 140 / 150 \ 160 in High Stage (Secondary)
Kind Regards.
Put a set of small vice grips on your return line. This will eliminate if this is the issue. Personally, I think it's more likey over fueling and really need to check float height. I have a great tool that replaces the spark plug and allows you to see the fuel burning in the combustion chamber. This would show you if its a fuel or vacuum issue.
