Post by guyph_01 » Wed Nov 30, 2011 2:06 am
Made a shade awning thing. Total cost $30:)
wombataaron
Post by wombataaron » Wed Nov 30, 2011 7:13 am
guyph_01 wrote:Made a shade awning thing. Total cost $30:)
I bought one of these off ebay for about the same price, it uses suction cups to stick on your roof, works a treat and its waterproof.
Today i put my car on jacks so i could fit a file between the rear tyres and the guards and file the inside of the guards down to stop my tyres rubbing:p Also jacked it to the height it should sit when it gets lifted next week to see how it will look and see if lifting will prevent the tyre scrub, hopefully it does:p
MY00 Outback
3" lift
Bullbar
Sump Guard
Yokohama Geolander AT-S
revmax
Post by revmax » Sat Dec 10, 2011 7:10 pm
took out he "Swish Swish" noise from the front disc brakes.
Post by Silverbullet » Sat Dec 10, 2011 10:15 pm
Hey revmax, that's interesting what material are the discs made of? Just curious since I doubt it would be plain MS.
Today I pulled my front seats out so I could fit some new covers properly. They are L touring wagon seats so there's not much room to move around them in the car :rolleyes: Decided to give it a vacuum while I was there, and fix down the dash mat and floor mats properly. Then replaced all the old vacuum lines under the bonnet, found I have a gaping hole in an inner CV boot :???: and the top rad hose leaks because the t/stat housing looks like the surface of the moon (cratered and rough as)
Might need a new fuel pump too soon.
revmax
Post by revmax » Sun Dec 11, 2011 4:45 pm
Brake discs are Cast Iron.
I machined the dics from the Brumby I recently wrecked, Blasted the wheel hubs and disck hubs then gave them a quick coat of sattin black.
so when I changed the discs over it whas a quick changeover. I will machine the discs that came off so they can be fitted quickly if ever need be .
Post by guyph_01 » Thu Dec 15, 2011 7:24 pm
Added a new accessory at the back of the wagon:D
FROG
Post by FROG » Thu Dec 15, 2011 8:34 pm
Excellent choice !! :D
and the colour scheme.......... :cool:
Post by guyph_01 » Thu Dec 15, 2011 9:03 pm
I think i'll paint the black red to match my sponsors:D:mrgreen:
Post by NachaLuva » Fri Dec 16, 2011 12:03 pm
guyph_01 wrote:Added a new accessory at the back of the wagon:D
car's looking great esp with the new accessory lol.
But there's one problem...you need to get the trailer lifted to match! :mrgreen:
Post by El_Freddo » Fri Dec 16, 2011 9:28 pm
guyph_01 wrote:Image
So when's the subaru conversion begin on the new accessory??
Post by El_Freddo » Fri Dec 16, 2011 9:30 pm
And does this officially make your subaru a boat anchor?? :p
revmax
Post by revmax » Sat Dec 17, 2011 4:54 pm
Outback got a wash and wax with nu finish once a year car polish.
thunder039
Post by thunder039 » Sun Dec 18, 2011 2:46 pm
put in my new springs this weekend king springs lifted 30mm and 4 wheel alignment. looks a lot tougher now, and no saggy rear end!
dfoyl
Post by dfoyl » Sun Dec 18, 2011 2:50 pm
Finally got some H4's for the Brumby. $15 from the trash & treasure market for the pair, WITH globes. Fitting them took about 1/2 an hour, it's a bitch to fit the connector on the pass-side as it doesn't clear the air-con condensor unless you have the light half out of the socket. Stupid design... Get to give them a try tonight :)
revmax
Post by revmax » Sun Dec 18, 2011 7:14 pm
done some blasting and prepin of the front guards , bonnet and grill for my Brum. more work on these pannels tomorrow. Had to stop cause I wore out my last blasting nozzle and gunna try some ceramic ones tomorrow, Hope gasweld has some.
OH BTW I bougth a 3HP 346LPM air compressor from gasweld and now my blast nozzles only last a little over 30minuets.
I have decided to fix this bonnet. Blasting the underside to remove the resprayed acrilic paint which is coming off pretty easy anyway. If i dont remove it it will peal whan I spray the 2pack. I can rub the top surface back pretty easy with my little orbital sander.
One of the front guards I got off Gannon the other from a wreck, they will both get rubbed back but one needs some welding first.
Post by El_Freddo » Sun Dec 18, 2011 10:23 pm
Nice revmax. Could you give us details (in a separate thread) about your home made sand blaster and how to make one? That would be super!
revmax
Post by revmax » Mon Dec 19, 2011 5:43 am
hey Bennie.
Here is one I done before, but I will add to it for my current set up later.
showthread.php?t=20423
Willie
Post by Willie » Mon Dec 19, 2011 9:49 am
We put some Michelin's on the XT Forester not long ago. Too new to have formed an opinion on them at this stage, but they seem to be quiet and wet weather grip appears OK. They replaced the Bridgestone Potenza's, which were a very good tyre. We got about 55k kms from them - much better than the Yoko Geolanders that came with the car - they needed to be replaced at approx 31k kms.
Willie.
Canberra
MY06 Forester XT Luxury
MY05 Pajero Exceed DiD
1975 VW L Bug (1303)
alang
Post by alang » Mon Dec 19, 2011 3:38 pm
Put a UHF guard aerial mount on the passenger side and dropped the tail gate to have a look at the hinge got one missing taken the inspection plate of the tail gate to see how hard it will be to panel beat the dints out
revmax
Post by revmax » Wed Dec 21, 2011 5:21 pm
Brum is getting a Bar.
Roll bar that is.
Picked up a 3inch alloy roll bar today and some extra sunrasia rims.
The bar needs a good rub back, holes welded up and a polish, I may even 2pack clear coat it.
BTW went for a Drive to Taree today and back 472km on 32.3l = 14.6km/L (FAR OUT)
