Which dual core(s) will fit in a 93 L Series?
MTB92
Post by MTB92 » Tue Dec 06, 2011 7:26 pm
cheers Toonga. :)
i do have a pretty good understanding of conductivity, i just have almost no experience with car radiators.
i am at the point of needing to make a decision on what radiator i will use to cool the EJ22, and as it stands i can see 3 options.
1. go new standard L series rad. some people suggest that this isn't enough to cool the bigger engine on a hot day 4wding.
2. aluminium L series rad. these are meant to have better cooling than the standard ones, and i think this option makes the most sense. (i guess i was partly wondering if i can just grab something off the internet, or if i need to go into a radiator shop and explain/order what i need :confused:)
3. get something custom made up :twisted:. this, i have no doubt, would keep the ej nice and cold but would also cost a lot more and is probably not necessary.
i will definitely get a new rad, as i have no idea how old the current one is but being in a 20yr old car i would be mad not to replace it.
hopefully 2nd Hand Yank will get something out of this too :rolleyes:
Post by TOONGA » Tue Dec 06, 2011 7:40 pm
Dang I found a place on ebay that manufactures out of Melbourne, now I can't find the link again :(
Venom
Post by Venom » Tue Dec 06, 2011 7:42 pm
Go single core alluminium. Its nice and thin which means you could probably fit a much bigger thermo fan than you can for a dual or triple core. Its cheap. Its works for every EJ, a stock Ej22 single core radiator keeps my H6 cool with no problems. I'd recommend a H-piece or two T pieces to bridge between the two heater core hoses, that way if it gets blocked you still maintain flow.
Every time my car(s) have heated off road its been due to a lack of airflow, and in my opinion thats best addressed with as much pulling power from your thermo's as possible. The bigger rad reduces the size of the thermo's you run, which to me is not addressing the problem you're having. If you have no AC then maybe go a dual core and fit a massive single fan on the front.
I'd really like a dual thermo fan setup with a full shroud covering the whole core, to me that would be the best cooling setup.
MTB92
Post by MTB92 » Tue Dec 06, 2011 7:46 pm
correct link? everything in that appears to be USA.
Thanks Venom, that makes sense. i think that will be the way i go.
Post by TOONGA » Tue Dec 06, 2011 7:49 pm
Link removed as Im not sure if he manufactures in Australia. Ive sent an email to him.
this is the link I found this morning.
http://www.ebay.com.au/itm/42mm-alloy-a ... 415f41bac3
vhr32
Post by vhr32 » Wed Dec 07, 2011 10:30 am
I bought a Nationwide Auto Parts radiator off eBay for $160 delivered. It's ok so far but I have not taken it on the beach yet and Tassie hasn't exactly got warm yet! :P
With normal driving it site about 3mm above the line on the gauge and rises up to 1/4 on massive hills, using the stock fan and unknown condition fan clutch.
I'll have to find out if the factory fan clutches can be opened up and I might put some Toyota fan clutch fluid in it to recondition it.
Post by TOONGA » Wed Dec 07, 2011 11:14 am
So I emailed this guy whose Ebay ad reads, albeit badly;
we are manufacture ,not importer.all shop order, bulk order ,wholesale is welcome.we also make-to-order. please feel free to ask.
and this is his reply
hi, they are manufactured in China, we have warehouses there, thanks!
- asi_performance
Post by El_Freddo » Wed Dec 07, 2011 12:41 pm
TOONGA wrote:So I emailed this guy whose Ebay ad reads, albeit badly;
"we are manufacture ,not importer.all shop order, bulk order ,wholesale is welcome.we also make-to-order. please feel free to ask."
"hi, they are manufactured in China, we have warehouses there, thanks!"
Classic!
I had my radiator made up by Aussie Desert Coolers in Perhan (I think) in the northern burbs of melb. I got a 3 core made up, does the job, is well fat but I reckon a single core would have been the go or even a dual core. I'm thinking of getting another one made up when/if I find the money for the job as I would like more space between the EJ and the thermos for a larger set of thermo fans...
Google them, their website should be the first to come up ;)
2nd Hand Yank
Post by 2nd Hand Yank » Wed Dec 07, 2011 10:18 pm
Wow, a lot has been discussed since late November!
So a single core, perhaps aluminium and some better shrouding for the fans would be the best for my L Series?
It sounds like one of the cheapest ways for good cooling. :)
Post by El_Freddo » Wed Dec 07, 2011 10:34 pm
Fan shrouding is key to good air flow through the radiator. You need the shrouding to be flush with the radiator core/cooling elements as a fan will naturally pull air from around it if there's not shrouding.
spike
Post by spike » Wed Dec 07, 2011 11:02 pm
ill throw my 2 cents in
i like the idea of a dual core, simple because it in creases the amount of water the system can hold. Ali is the way to go, i dont know many people still using copper in anything.
Oil coolers are deffinatly a plus, first thing you should do if you think its getting hot, however it lowers oil pressure and oil coming out of the cooler is 60 percent air and roots bearings. If your running a front bar can i suggest fitting an oil cooler the size of your number plate, sited behind your number plate, if your doing hard work move the numberplate to the lower holes.
Keep the clutch fan as long as you can, my thermo fan is hooked up to the ignition always on and never lets the car down. Shrouds are nessecary, if your running thermo fans only go with an air evacuation sheet (fancy word for a big shroud)
I will have to do somthing about mums cause its boiling its nuts off..........
Also dont jack the bonnet up for better cooling, it doesnt work it creates a low pressure zone and sucks more air in. Best bet is to vent somwhere else (i will be doing some experiments about it)
discopotato03
Post by discopotato03 » Thu Dec 08, 2011 1:53 pm
Oil coolers only ever reduce oil flow if the plumbing is too small and or the core is too small .
Please tell me how an oil cooler introduces air into the oil - aside from the inlet and outlet they are a sealed unit .
At the end of the day an oil cooler is merely a radiator designed to contain a different fluid under higher pressure and generally temperatures . If radiators had to cope with 100 plus PSI and 140+C temps they would be constructed like oil coolers too .
Really people for the last time yes aluminium is the best radiator core material to use but if a narrow (thickness wise) single row core is marginal (cooling wise) a properly made twin row copper core one will reject heat more easily .
The only way you are ever going to get an aluminium radiator that will fit as the factory has it is to have a one off one made up - but $700 dollars later ...
Your calls , Paul down at Subareck in Adelaide had copper twin cores made up for half of what the custom allys would cost - and he rallied an RX turbo with them .
He obviously came up with a suitable core to suit whichever is the wide tank side of a std L Series radiator . AFAIK no one makes a wide replacement tank for the narrow side so you have to use an MY style brass one . Now had the core been aluminium one you'd have had a fun time trying to join alluminimum to brass because the MY tank isn't designed to join with foulded ears and rubber seals . What you can do however is solder the copper folded ear twin core to the soldered type conventional MY tank - and then everything just about falls in the car .
Rad core poos itself , no prop . New core and fit up like std L on one side and solder the other . If you took the expensive fabbed ally one you have to cut the core out of the tanks and weld it all up again whilst maintaining the same width with the "hacked" tanks .
Anyway you can believe me or not but I've been through the process of single copper/Japanese made Koyo single aluminium/Subareck copper twin row . Provided my car has a full sump of oil and a full cooling system it never overheats . I use only the belt driven fan too BTW and it is a pure road car - no sand dunes .
My conclusion with all EA82/T power cars is that most of them are long in the tooth/tired and run hotter because of it . I don't recall people complaining about them when they were new so what the factory fitted must have been generally adequate when in fresh condition .
Fact of life is that more power means more heat so turbo versions need more cooling capacity if worked hard .
I also think that Like old Bluebirds L Series cars don't have particularly good airflow through their engine bays which is hard to solve . Possibly bonnet outlet vents would help if you could get them to draw hot air out .
Actually if I was going into the dunes I'd probably consider pulling the bloody thing off - ever tried that one ?
And on the slightly spaced up bonnet thing , mine is and with hinges that unbolt from the body this is very easy to do .
Don't believe it works ? Try it and run your hands up the slightly raised sides of the bonnet with the engine running , yep thats warm post radiator air you can feel escaping out the sides and yers can thank Coxy for that one too . You do get an area of slightly higher pressure just in front of the windscreen but not along the sides of the bonnet .
Try every trick with these cars because a little bit here little bit there can make all the difference , same with most things automotive - generally .
A .
spike
Post by spike » Thu Dec 08, 2011 2:28 pm
discopotato03 wrote:Oil coolers only ever reduce oil flow if the plumbing is too small and or the core is too small .
im not really able to answer that question, its just what ive known. Colin chapman used it as a rule and i belive it. i belive its the cavitation at the pump and the low to high pressure.
-------------oil in
spike
Post by spike » Thu Dec 08, 2011 2:31 pm
[quote="discopotato03"]Oil coolers only ever reduce oil flow if the plumbing is too small and or the core is too small .
QUOTE]
i guess im not able to answer the second question, its just what ive read. colin chapman belived that so i will too. Perhaps its the cavitation or the mixing as it enters the sump.
as for the first its not flow its pressure
oil in ------------------ oil out
you start cramming oil into tiny passages and the pressure builds on one side, lowering the pressure on the other. you cant have oil cooler tubes the size of the oil feed
spike
Post by spike » Thu Dec 08, 2011 2:37 pm
another note on discos post, yeah when they came out they were ok.
get it flushed/rodded and go from there or get a new stardard one and make sure all your fans and stuff work
Post by sven '2' » Thu Dec 08, 2011 6:47 pm
I ran with one Paul's dual core on my NA L and then the EA82T. Unfortunately, they are not very robust - mine was dinged up too easily as per avatar(!)
Setup: Had one fan with a shroud, one without. Quality waterpump (not all waterpumps are =) - all standard. Very good coolant mixed correctly.
No fancy fan switching, no Homer go fast vents, no mods aside from the rad itself.
I recall only ever once overheating in the EA82T - suppose though towing another vehicle backwards on shell grit beach on a balmy 35C day down at Beachport one summer will do that
A standard cooling system in good order, good coolant is a good start before dual cores, oil coolers etc. I would suggest a fair percentage of cooling systems have issue(s) before they are stressed by what we do...
discopotato03
Post by discopotato03 » Fri Dec 09, 2011 12:10 am
spike wrote:im not really able to answer that question, its just what ive known. Colin chapman used it as a rule and i belive it. i belive its the cavitation at the pump and the low to high pressure.
-------------oil in
I can't see Colin Chapman making a statement like that because it doesn't stand up to any engineering reasoning . When you fit an air to air oil cooler to an engine you make sure its sized to make no measurable flow restriction because if you don't its a greater danger to the engines health than oil temperature . Most competition engines run external oil coolers and they'd die a quick death if they posed a flow restriction or were the cause of oil airation to any degree . An undersized oil cooler system is a mugs choice not an engineers one .
A .
spike
Post by spike » Sat Dec 10, 2011 3:46 pm
sorry the flow and pressure was just what ive been told around the traps
the one about aeration was Colin Chapmans
SURVIVAL RULES (YOURS AND THE DRIVERS)
1. The keywords are elegant simplicity. Each part doing three jobs at least.
2. The objective is to win the race. Remember, the car has to finish and a tired, a blistered driver won’t help.
3. Car must be designed so that a pre-race check can be carried out completely by one man in six hours. Rectification or readjustment is extra.
4. Pre-race check sheet is supplied to the operator. With each new type of sheet, operators will add to, but may nor delete from this. Designer starts the sheet, build and development will add to it and engineering director signs it into law.
5. (Anti)-roll bar, camber, wing, brake balance bar changes must be possible in five minutes and repeatable. These are no good if they cannot be identified and repeated. Avoid infinite variable screwed adjustment.
6. Murphy is a racing mechanic and works for Team Lotus. If it can be assembled the wrong way around he will.
7. Never design or cause to be made something that cannot be inspected. Again, never design something that cannot be seen to be safe or that needs special equipment to prove it.
8. All spherical bearings need protective covers.
9. You can’t change people, so make the car easy to adjust and maintain by easy access.
10. A grease seal over a universal near a brake disk is better than none at all. It will fail before it gets renewed so provide a finger disk to direct the grease clear of the brake.
11. Stress suspension for a 3g bump on a 2g corner.
12. If the driver believes the car is strong enough it’s worth more than one second a lap. Avoid birdcage structures. All tubular structures to be 3-inch circumference. Adjust the gauge for load.
13. Never use banjos on the pressure side of the fuel system.
14. Never use ‘O’ rings to seal negative pressure.
15. All material, including human skin, are notch sensitive – some more than others – so use appropriate radii.
16. Remember, all engineering materials are rubber like. They deflect to some degree under the slightest load and will expand to some degree in the presence of even a lighted match. Everything resonates, even brake pipes.
17. All flexible fuel and oil lines are to have screwed ends and armoured flexibles.
18. Drivers feel corners through the seat of their pants, their heels and above all, under their armpits. Ensure seat back is 100% rigid and fits.
19. Gearchange linkages wear, bend and stretch. Provide 100% over-travel clearances in all directions.
20. Provide throttle pedal stop at the pedal and the return spring at the throttle slides, preferably in compression so it still works when broken.
21. Remember, a frantic driver can put 250lb (113kg) on a pedal or a gearlever.
22. Do not try to exceed 20ft (6.1m) per second in a water pipe, you won’t. Neither can you exceed 12ft (3.7m) per second for 30/30 oil.
23. 90-degree welded bends, i.e. 45-degree scarf joints, reduce flow by 5% even if you remove internal nuggets. Double cut and shut ie 2 x 22.5-degrees, cost 2% and a 4D radius just ½%.
24. Always specify the size of ball you must be able to roll down a pipe system to ensure adequate flow.
25. Providing oil and fuel tank dipsticks may prevent a lost race through inaccurate consumption checks.
26. Wheel deflections, camber changes and toe steer required during the no spring bump test must be specified on suspension data sheets by designer and countersigned by him when he has seen the test, and a photocopy put into the cars log book.
27. Car acceptance test includes proving that the fuel system draws down to one pint (.6 litre) from five gallons (21 litres) whilst running at least at 90% of the test circuit record time.
28. Don’t invent new oil tanks, use the ones proved to work. Remember the fluid that comes out of the oil coolers may look like oil, but it contains 25% by volume of air at least.
29. Air leaks at the suction side of the oil pump destroy one engine per race. Keep Duckworth poor.
30. Brakes recuperate better with a head of fluid above the master cylinder. Low mount the cylinder with a a high separate reservoir, with a big enough pipe. And don’t forget the scent spray.
Always pressure bleed.
Air in motion is the best heat insulator.
If the airbox is working, there is a load of 150lb inside it and it will bulge or blow off if insecurely fastened. If insecurely fastened and it doesn’t blow off, it doesn’t work.
You cannot change the basic laws of nature, no one has yet. Let Newton, Charles, Boyle, Bramah and Bernoulli rest in peace.
Lightening holes should be the last resort of the designer. The most effective way of weight saving is not to start with it.
Measured over the wheelbase, one axle restrained and lifting one corner of the opposite axle, torsional stiffness of the entire structure must exceed 2,500ft.lbs (3456Nm) per degree. The variation in stiffness per foot of wheelbase must not exceed +/- 10% or 15% between two adjacent sections otherwise fatigue failures are likely.
Keep suction lines as short and straight and simple as possible: no rubber elbows at pump inlets.
If there is no other way to join two components together than with bolts, remember they work by stretching between .003” and .005” per inch of length. Make sure they can do, even if you have to provide a waisted section to keep the local stretching near the elastic limit of the material. 3% nickel is best.
Although titanium is 70% the weight and 1000% the cost of high-grade steel, it is 50% more resilient and 1000% more gall sensitive. Use it with care, after you have assessed maraging steel, which strength for strength is also 70% the weight of high-grade steel, 200% the price and just as rigid.
Corner weight tolerances +/- 2%. Enter in the cars log book.
The deflection of the lowest part of the wheel rim, relative to the tub centreline should not exceed the static corner weight/2000” (CW/50.8M) when 1g cornering load is applied. Neither should the camber change by more than 20 degrees during this test.
All systems must be flow tested before the car is started. Flows required must be marked on the system’s drawings. A bucket and stopwatch is quick and accurate e.g. Fuel system must flow 250 pints/hour with 100psi pressure.
Keep a pair of every drivers driving shoes or sole patterns, suitably labelled, in the Design Office.
Remember cars will run with transducers on suspension travel, throttle slides, strain gauges on wishbones and wing mountings and ‘black boxes with invertors’. Bear this in mind without compromising design.
Always weigh the car before and after paint, including signwriting. Weight increase not to exceed .05%.
Racing cars get out of line. Always provide and prove 30 degrees of lock so drivers can get them back. Saves one shunt per year.
Always measure spring frequencies against specifications after no spring bump tests. Designer enters results in log book.
All log book entries signed legibly and dated.
Operations will not accept, neither will we offer them a car without a log book, which will show no spring bump tests, toe curves, corner weights, flow tests, tilt rig test results and contains data sheets. Losing the log book is a capital offence.
discopotato03
Post by discopotato03 » Sat Dec 10, 2011 10:55 pm
Col makes sense there but note he is talking about a dry sump race application not a wet sump road one .
Not sure if you know but dry sump systems use basically a shallow tray on the bottom of the block to collect drain back oil and its removed from here by a scavange pump and sent to an oil tank or reservoir .
With the sort of revs many race engines run there is a lot of "windage" off the crankshaft and "crank scrapers" are used to try and seperate the oil from the cyclonic currents in the crank case . I believe some of this ends up in the oil tank though its probably possible to make the oil spin radially in the tank so the lighter air moves to the center and rises to the top .
BTW where he mentions keep Duckworth poor I'd say hes talking about Mike Costin and Keith Duckworth who together formed Cosworth many years ago .
A .
spike
Post by spike » Sun Dec 11, 2011 7:13 am
yes there are differences between race and road but id still believe it about the aeration because think of what will happen if we dont, better safe than sorry
