Step one. Remove the bearing by undoing the 27mm nut, then use a gear-puller to remove the flange from the splines. Then very carefully, using a copper hammer, tap the end of the shaft to remove the bearing
Step 2. Cut the shaft about 30mm from the bearing end.
Step 3. Put the bearing end in a lathe and turn down the weld enough to remove the short length of shaft (a huge thanks to Nev's dad for letting me use his lathe)
Now I just have to press the shaft onto the bearing end, and then with it back in the lathe (to hold it dead straight)
I'll weld it back up and put the bearing back on and all should be sweet.
I'll update as I progress
