A arm subaru
A arm subaru
i was thinking about it while i was doodling about my offroad beast that im collecting parts for
why hasent it been done? or even tried?
i might draw one up if i get the chance, need to work out where i can place it, will have to be above the gearbox about mid point with the lower mounted to the g/b and cut the inner wheel well out
pickstock racing fabrication
pickstock racing photography
GETDIRTYCLOTHING
GETDIRTYCLOTHING
yes a double wishbone setup, however with a long travel emphasis.
much like offroad buggies and the like, ill upload some inspiration photos later
GETDIRTYCLOTHING
GETDIRTYCLOTHING
http://pix.race-dezert.com/displayimage ... m=59&pos=3
heres a photo of the sort of design, but it wont be set so close to the middle of the car due to gearbox and engine
GETDIRTYCLOTHING
GETDIRTYCLOTHING
- d_generate
And won't have half the travel because it'll be too short.............Unless you have the wheels outside the body.
- mud_king91
- Mr Top Hat
- mud_king91
is that in reference to the photo? or to the current amount of travel that you can get from a subaru?d_generate wrote:And won't have half the travel because it'll be too short.............Unless you have the wheels outside the body.
im not looking for a huge amount of travel, i just want somthing different, camber when and where i want it and other little things im chasing.
GETDIRTYCLOTHING
GETDIRTYCLOTHING
- vincentvega
deffinatly what this thread is, if you go back to the start of the thread it was a concept ideavincentvega wrote:another "im gonna" thread...
unless you are going to stick the wheels way outside the body there isn't room.
i had a look and did some napkins on my day off. The only way it can be done is by cutting most of the original car away such as the inner guards and the rails.
GETDIRTYCLOTHING
GETDIRTYCLOTHING
