EA82 water pump differences found !!
there's been a bit of discussion re water pump differences between EA82 n/a and turbo. some have said turbo pumps differ to carby pumps. spare parts listings state deck height differences . Measure deck height between the face against the block and the outer face of pulley flange.
105mm & 110mm. I ordered a 105mm for my GLTA (turbo listed as 105mm) and find pump that came off EA82T almost originally in it was 110mm. SHOOT!
others have said they've bought normal available pump and fitted just fine to turbo motor.
Looking at pumps off n/a, turbo and Vortex turbo I think I gonna have the final word.
to run flat ribbed drive belts USE 105mm deck height
to run V belts USE 110mm deck height
so i spose vortex pumps are different to L series ?
problem should be solved with the hydraulic press
- vincentvega
- discopotato03
