www.subarugearbox.com.au
Has anyone use these guys? It seems they have a lot to offer.
They work on exchange, no biggie there as they replace all the bearings and syncros at the same time. I also hear "ka-ching!, ka-ching!, ka-ching!" rolling over as you talk about this!taza wrote:I might have to send my Gearbox to them soon enough for a rebuiltMight get a front lsd while im gettign it done. Maybe a better centre lsd too.
Bennie if it needs to be done it needs to be done. I will keep driving my Subaru though until 1st gear is gone completely. I know it will cost around the $2000 mark probably. But If I do get it done all new syncros will be added aswell as a new 1st and 2nd gear. Then since the box will be out I might get a lsd, saves having to pull it out and do it laterEl_Freddo wrote:They work on exchange, no biggie there as they replace all the bearings and syncros at the same time. I also hear "ka-ching!, ka-ching!, ka-ching!" rolling over as you talk about this!
I'd be budgeting for more than that figure, especially once you include freight etc.taza wrote: I know it will cost around the $2000 mark probably. But If I do get it done all new syncros will be added aswell as a new 1st and 2nd gear. Then since the box will be out I might get a lsd, saves having to pull it out and do it laterAtleast if/when I get it done the box will be good for another 250,000km.
The Helical front LSD would be the way to go as H-top has said.
And I would expect more than 250,00km from a gearbox - subaru one anyway... My EA box got over 400k km on it then went into a mate's L and kept him going without worries (and with working 4wd), it's now the paddock bomb
Make an enquiry with them so you know what you'll be up for - Venom has just done this and sent me a copy of the reply, it was about what I was expecting + a bit more!
I can't find a definitive answer but i've seen it mentioned that helical LSDs won't work when a wheel leaves the ground. If someone could prove that wrong it would be good, because i'm putting one in my car.
You're looking around 2,400 to 3,000 plus the exchange. Thats with a viscous centre, either second hand or new.
