stubaru's ej22 conversion
hey mate another quick question have you got the fans in yet??
hows the fit with the 10" fans?? a pic would be great:)
Dann
Looking for:
- LSD diff
Dann
Looking for:
- LSD diff
Awsome, thanx for that
Dann
Looking for:
- LSD diff
Dann
Looking for:
- LSD diff
That's pretty good! Mine are closerstewbaru wrote:Here's a photo of the clearance, its tight but looks closer in the photo than it actually is.
I can get you a pic of my setup if you like...
Custom sounds expensive, i'm starting to think the l-series is better than women at draining my bank account. If you don't mind me asking how much did the rad cost you? It would be nice to go custom and for it to bolt up but at the moment i'm thinking a bit of cutting and welding to fit the lib rad is my best option.El_Freddo wrote:That's pretty good! Mine are closerA three core radiator will do that
I still think that the 3 core is too big for the EJ, I'd love to try out an all copper/brass single core radiator that's setup for the EJ if I had the money... always the way!
Nick
end of exams = progress.... looks as though she'll be already for the weekend with a little help.. just in time for a nice bath in a certain black lake.
to do list:
to do list:
so she's 95% complete now.. engine runs on 2 cyclinders not 100% sure why but once we get the temp gauges etc wired up its off to my mates for injector service etc to hopefully sort it out.. got the new lib radiator in aftermarket fans and changed a few things that needed doing get some missing various pipe work tomorrow hopefully then shes pretty much complete.
to do list:
to do list:
Yeah not exactly sure. Changed the spark plugs today, and we have spark. Also when we pull the injector plugs off it makes no difference to how it runs at all, both of the injectors are pulsing aswell.El_Freddo wrote:Sounds good mate!
Are you sure it's injectors that is the issue with the 2 cylinders that are down??
Have to check the compression tomorrow, fingers and toes crossed we get good numbers.
Any other ideas about what it could be?
compression 180-185 across too cyclinders.. where and how to get injectors sorted? any info appreciated my understand is that the engine sat for quite a while.. probably has some baring on them not working.
to do list:
to do list:
pulled an injector rail out of my car today and swapped them out ran nicely so just waiting on the injectors to come back from being cleaned now
to do list:
to do list:
so yeh we took her out for a bit of a play today and i'm not too impressed with nic drowning my phone which was sat in his centre console.. he's got a picture of 2 which he'll post up ..
to do list:
to do list:
Yeah first off-roading with the ej22 ended with this......
We had gone through a similar puddle to the right and it was reasonably shallow so didnt bother checking the next one, and turns out there was a massive ditch in the middle of that one haha all good though the interior is soaked but thankfully it wasn't deep enough to get water in the intake
only one to get out of the car with a working phone, lucky you.
to do list:
to do list:
