alternator options?
alternator options?
so i reckon my alternators packed up in the l. Any suggestions on an upgrade?
not many choices for the ea82, i went thru about 5 on my ea82, i was running wayyy too much gear.
do some research into MQ/MK patrol alternators. I think theyre very similar.
- TOONGA
If you have your lights on at idle and you rev the engine do the lights get brighter? if so the first thing to check is the fusable links, as they may look fine but with age they lose conductivity. my brumby had the same problem it was the fusable links as the previous owner had wrapped speaker wire around the remains of a fusable link and hid it under the plastic cover.
If this is related to the CD player switching on and off, I would test the circuit the CD player is on first, then I would check the output of the alternator against the voltage specifications stated in an FSM or other manual.
from reading your thread about the CD player I would say it is switching off as it is either earth shorting or isn't getting a constant positive supply. while you will have made every effort to install the CD player properly the same cannot be said for the person who owned the car before you.
the previous owner who installed the CD player into my brumby crosswired all the speakers (stereo ran mono) and wired the power to the heater from memory even though there was power from the plug for the stereo available.
Look for wires that don't make sense or have excessive tape on them Im pretty sure you know what I mean
TOONGA wrote:near the positive terminal just next to the battery will be a skinny black box with a removable cover under the cover will be 3 coloured wires these are the links
Yeah the fusible link's box is mounted on the radiator overflow bottle that's beside the battery on the Passenger's side - can't miss it.TOONGA wrote:If another L series owner could confirm the location that would be great
And for the alternator, the USMB guys seem to use one from an MX5 or something similar.
Talking about fusible links - guess who had one blow last weekend on the way up to Hotham (via the pub)??? And a 30A fuse shoved in there doesn't do the job with an engel and high beamsEl_Freddo wrote:Yeah the fusible link's box is mounted on the radiator overflow bottle that's beside the battery on the Passenger's side - can't miss it.
Sorry for the hijack, just thought I'd share
lol Bennie, I was naughty with my wagon before i changed all the links to circuit breakers...i was melting 8guage stereo power cable as a fusible link...
