L series With Liberty D/R AWD gearbox. Tail shaft help
Post by guyph_01 » Thu May 26, 2011 12:33 am
Hi guys,
I just wanted to find out want those who have used a Liberty D/R AWD gearbox gearbox in there L series have used for the tail shaft? I know it must be shorten. I saw somewhere by 65mm.
Now i remember that Toonga has used a mix match of lib and L tail shafts to get the perfect length by that was in his brumby.
So i want to know if anyone has done the same?
Are impreza shafts two piece?
Also could someone give me accurate measurements of how long or how much shorter it must be?
Thx
Post by RSR 555 » Thu May 26, 2011 3:56 am
Not sure what the difference is off hand but if you have a Liberty and an L box on the ground, then you should be able to do the maths.
This mix/match worked in Jule's car because we didn't have to worry about where the centre bearing sat.. the MY doesn't have one, so we made a temp steel strap (which I believe is still in place?). In the L's you're best off using the L rear piece and getting the front piece modified.
Post by AndrewT » Thu May 26, 2011 11:26 am
yeah 65mm shortening on the front piece works.
Post by guyph_01 » Thu May 26, 2011 11:28 am
Do you guys know where can i get this done?
Post by guyph_01 » Thu May 26, 2011 11:36 am
Good news, Drive shaft australia does it for $180, shorten and balanced... not to bad.
Anyone knows somewhere else that i could get a quote from?
Post by AndrewT » Thu May 26, 2011 11:46 am
I've used Driveshaft Balancing Services in Osborne Park before.
Make sure the CV's on your shaft are in tip top condition. If they need to replace any, they only use cheap Chinese ones and from experience they flog out after a very short time.
They rekon that's the only CV's they can get these days, but to be honest I was planning on trying a different place next time I need a tailshaft done.
Recommend you just phone around all the places in Perth, there aren't too many. Use whitepages, google etc.
Post by guyph_01 » Thu May 26, 2011 12:31 pm
I'm talking about the center tail shaft. Are you talking about the cv shafts?
Post by Alex » Thu May 26, 2011 12:40 pm
cvs = uni joints andrew?
vincentvega
Post by vincentvega » Thu May 26, 2011 12:52 pm
depends on the model of car. some have CV joints and some have unis
Post by RSR 555 » Thu May 26, 2011 1:34 pm
You can try and ring around but from my experiances $180 is pretty damn cheap
Post by guyph_01 » Thu May 26, 2011 1:41 pm
yeah thats what i though when they gave ne that quote. Was expecting around the $300 mark.
Post by AndrewT » Thu May 26, 2011 2:02 pm
yeh uni joint sorry.
I've had 3 tailshafts shortened and balanced, never paid over $170 except for when I got a few of the joints replaced at the same time.
Post by guyph_01 » Thu May 26, 2011 2:27 pm
where did you get them shortened?
Post by AndrewT » Thu May 26, 2011 2:59 pm
here....
AndrewT wrote:I've used Driveshaft Balancing Services in Osborne Park before.
Post by guyph_01 » Thu May 26, 2011 4:44 pm
They want over $250 now:(
Post by guyph_01 » Tue Jul 12, 2011 8:14 pm
Hi guys,
I didn't want to start a new thread, This goes out to all the L series owners that have put a Liberty AWD box in there car. I would like by how much you shorten the tail shaft? I didn't want to start a new thread.
I know Andrew you said 65mm but i just want to make sure with the other replies, so if you also shorten it by 65, plz let me know. I'm thinking i can send it to get done and save time.
Post by AndrewT » Tue Jul 12, 2011 9:40 pm
Jump under your car for 5 minutes and take a measurement to double check.
Post by AndrewT » Tue Jul 12, 2011 9:50 pm
Yeah actually it could have been 75mm. or maybe 55mm....actually maybe it was lengthened.
Or it could have been 65mm :) I think I even have the invoice somewhere which lists it.
To be honest, give or take even 10mm is probably fine - those splines are long.
Post by RSR 555 » Wed Jul 13, 2011 2:55 pm
Best way to meassure without the box in the car is..
1. Measure the full length of your L box
2. Measure the full length of the Liberty box
3. Add or Subtract the difference
Problem solvered.. just don't paint it Red !!
Post by guyph_01 » Wed Jul 13, 2011 3:33 pm
Cool, thx Paul.
Ok i'll paint it Yellow then:p
