Rupert, the 89 l wagon
Meet Rupert, my 89 touring wagon, with many modifications to come
- Rupert3.jpg (107.75 KiB) Viewed 6841 times
- Rupert2.jpg (108.3 KiB) Viewed 6836 times
- Rupert1.jpg (109.79 KiB) Viewed 6869 times
Nice,
I like the look of the early style grill. The dash buttons must also be different and cool:p Let us know what you do to him:D
ok, so, planned mods include 3 or 4 inch lift, prelude rear springs, front heavy duty springs, gauges to monitor the engine, a conversion one day, bullbar (if i can find 1 in sa), roof basket, 6 spotties, maxxis buckshots, dual batteries, CRUISE CONTROL, onboard air, rear wheel carrier, shower and. . . . . . . .
Rupert looks like our twins, Guy.. he just has the early model grille and some import corner lights but the rest will be all the same. We can start a grey touring wagon club soon
Nice mods you have planned there Ben.. sounds like it's going to become a great getaway vehicle
- FROG
Pm me your vin and I'll see what that revealsthelman wrote:. Apparently rupert is a 'limited edition' can anyone fill me in?
Great job mate, but no one believes you without pics:)
HahahahaEl_Freddo wrote:Ah... someone's catching on!
Definately either loose connections or the unit is crappy
Or the ignition switch is dodgy on the accessories part of the switch. Check the soldering on the back of the ignition switch - you'll find it mounted on the passenger's side of the steering column at the back of the key barrel.
Otherwise check the connection you made to the wire the turns on with the accessories and see if its a good connection. I hope you used a decent connector or some solder and heat shrink!
so today i mounted the gauges in rupert. Water temp, oil pressure and ammeter. Oil pressure and temp on drivers side and ammeter in middle. All are mechanical. Havent got around to wiring up the lights yet, but will do when i connect the gauges, hopefuly next weekend.
- Gauge 2.jpg (102.66 KiB) Viewed 6616 times
- Gauge 1.jpg (106.32 KiB) Viewed 6621 times
- Ammeter.jpg (103.22 KiB) Viewed 6625 times
