Where dose this pipe go
yarney
Post by yarney » Sat May 21, 2011 4:45 pm
The engine is a 99 gt forester i have taken off the turbo. The pipe in pic1 doesn't connect to anything atm.
In pic2 this is where it goes in the block
In pic3 there is a male piece under the throttle body intake in pic2 you can just see it directly under the intake red arrow dose the pipe connect to it? I cant see that close to see what it is (even with glasses on) there is nothing in the manual about it
The pipe looks like it hasn't been on for quite a while it is very hard
I will replace it
Sorry about the pics (phone camera)
Jan
Post by TOONGA » Sat May 21, 2011 7:33 pm
Jan these photos of yours show the crank case breather and pcv valve (positive crankcase ventilation)
yarney wrote: Image
crankcase breather
yarney wrote: Image
pcv valve
yarney wrote: Image
this diagram shows how the pipes need to be connected for the crankcase recirculation to work it is from the 92 liberty FSM
here is how it looks in my liberty
hope this helps
yarney
Post by yarney » Tue May 24, 2011 6:46 pm
Thanks TOONGA
Yes that's what i need to know
Thanks for the pics :D
Jan
Post by TOONGA » Tue May 24, 2011 7:10 pm
Jan not a problem I know it is hard to see in the photos but where the crankcase breather comes out of the block, there is a "T" in the pipe and a smaller pipe heads into the aircleaner from there. As you can see in the photos the breather then goes into the PCV valve.
