Rupert, the 89 l wagon
thelman
Post by thelman » Mon May 16, 2011 6:18 pm
Meet Rupert, my 89 touring wagon, with many modifications to come
Post by guyph_01 » Mon May 16, 2011 6:40 pm
Nice,
I like the look of the early style grill. The dash buttons must also be different and cool:p Let us know what you do to him:D
thelman
Post by thelman » Mon May 16, 2011 6:44 pm
na mate, has same dash buttons as yours
thelman
Post by thelman » Mon May 16, 2011 7:43 pm
ok, so, planned mods include 3 or 4 inch lift, prelude rear springs, front heavy duty springs, gauges to monitor the engine, a conversion one day, bullbar (if i can find 1 in sa), roof basket, 6 spotties, maxxis buckshots, dual batteries, CRUISE CONTROL, onboard air, rear wheel carrier, shower and. . . . . . . .
Post by RSR 555 » Tue May 17, 2011 12:49 pm
Rupert looks like our twins, Guy.. he just has the early model grille and some import corner lights but the rest will be all the same. We can start a grey touring wagon club soon :rolleyes:
Nice mods you have planned there Ben.. sounds like it's going to become a great getaway vehicle :)
thelman
Post by thelman » Tue May 17, 2011 5:18 pm
thats the plan mate. Have sold my xr8 now and am looking at an early lib as a daily. Apparently rupert is a 'limited edition' can anyone fill me in?
FROG
Post by FROG » Tue May 17, 2011 8:36 pm
thelman wrote:. Apparently rupert is a 'limited edition' can anyone fill me in?
Pm me your vin and I'll see what that reveals ;-)
Post by El_Freddo » Sat May 21, 2011 11:22 pm
I know that paint colour came out for a very short time - even the trim colour is different to the regular grey that came out with everything else...
Looks like you've done some research into your mods. Good stuff!
thelman
Post by thelman » Tue May 24, 2011 9:46 pm
spent a few hours today putting a cd player and new speakers in. The facsia came from subareck, $15, and the new speakers (hidden in original holes) are 6 inch kickers. When i get around to it, i'll stick some more in the back
Cd in rupert.jpg (101.81 KiB) Viewed 6786 times
Post by guyph_01 » Tue May 24, 2011 9:53 pm
Great job mate, but no one believes you without pics:)
Post by El_Freddo » Tue May 24, 2011 10:28 pm
guyph_01 wrote:Great job mate, but no one believes you without pics:)
Ah... someone's catching on!
thelman
Post by thelman » Tue May 24, 2011 10:34 pm
damn pic didnt attatch first time round lol
Post by guyph_01 » Tue May 24, 2011 10:59 pm
El_Freddo wrote:Ah... someone's catching on!
Hahahaha
thelman
Post by thelman » Wed May 25, 2011 6:01 am
ok, seems a bit weird, the cd player keeps switching off while driving. The earths are good and main power comes directly from the battery. My only thought is i may have to rewire the yellow accessories cable. Thoughts?
Post by RSR 555 » Wed May 25, 2011 12:18 pm
Definately either loose connections or the unit is crappy
thelman
Post by thelman » Wed May 25, 2011 12:42 pm
good unit. Only bout 10 month old. Was working fine in the vt. Have done dozens of installs and never had the problem before
Post by El_Freddo » Wed May 25, 2011 2:44 pm
Or the ignition switch is dodgy on the accessories part of the switch. Check the soldering on the back of the ignition switch - you'll find it mounted on the passenger's side of the steering column at the back of the key barrel.
Otherwise check the connection you made to the wire the turns on with the accessories and see if its a good connection. I hope you used a decent connector or some solder and heat shrink!
thelman
Post by thelman » Thu May 26, 2011 7:42 pm
well it aint any of the connections, all have power even when its having its hissy fit. Alternator maybe? Any suggestions?
Wagonman
Post by Wagonman » Fri May 27, 2011 12:52 am
I know that when my battery and alternator battled against each other and killed themselves the radio was the first thing to start playing up.( i dont know why?? anyone?) I would be checking your battery and alternator..
thelman
Post by thelman » Sun May 29, 2011 7:06 pm
so today i mounted the gauges in rupert. Water temp, oil pressure and ammeter. Oil pressure and temp on drivers side and ammeter in middle. All are mechanical. Havent got around to wiring up the lights yet, but will do when i connect the gauges, hopefuly next weekend.
Gauge 2.jpg (102.66 KiB) Viewed 6609 times
Gauge 1.jpg (106.32 KiB) Viewed 6614 times
