And what are some cheap mods i can do to it to get more ponies out of it?? Cheers for any suggestions.
Liberty Mods
Liberty Mods
Hi Guys, im new to this forum. just a few questions if anyone can help, im looking at a 92' Subaru Liberty GX. Only problem with it is blown head gaskets, and only $200 from a trusted mechanic/friend. Anyway just thought i might ask, how hard can the gaskets be to change??
i think its an engine out job on those ones but still not very hard if you know what your doing, mayeb worth offering 300 if hes happy to help you fix the HG?
or for more ponies just drop another EJ engine in. depends on what fits but usually they are pretty interchangable.
as for other mods it depends on the engine, turbo or NA
simple cold air intake might get you a bit more
free flow exhaust might be dubious but people like it
pickstock racing fabrication
pickstock racing photography
GETDIRTYCLOTHING
GETDIRTYCLOTHING
Doing a headgasket can be a tricky job. Have you done much mechanical work before?
If you have not, i advise you to let somebody else do it.
As for power increases, there aint many, as these 4 valve per cylinder fuel injected engine make good power for their size.
Just a new panel filter (dont bother with K&N types) and a new fuel filter, get new spark plugs and leads when the engine gets a new headgasket. You could maybe put a new muffler on the rear to make it sound a little better (but dont get a cannon, please) and you might gain maybe 1 or 2 hp.
Thanks for the info guys, really big help. I have done a few Gasket changes but never on a boxer thats why i thought i better ask. I saw the gx only a few days ago and fell in love with it lol. And when my mate said it was only $200, i simply couldn't refuse. He did warn me that he hadn't actually taken the head off to have a proper look, only a compression test. Im worried there might be a cracked head, but still $200 is still worth it... isnt it??
yeah 200 is still good even if it is cracked, like we said before just do an engine swap i find them easier then changine hgs lols
GETDIRTYCLOTHING
GETDIRTYCLOTHING
A cracked head on an EJ is a rarity, but if it was overheated, i would defiantly have the head resurfaced
Best bet is to get a Gregories or Haynes service manual, read the headgasket section a few times and pull the heads off the engine.
If there is rust in the bore from water that may have been laying there, go find yourself a new engine.
you could bolt a turbo onto it, but it isnt recommended. A turbo motro swap is easier, cheaper, and more reliable.
im thinking you should piss off your ej22 and go an ej20 turbo motor.
I figured as much as i have always heard that bolting a turbo on any stock car that isn't built for it can be risky.
unfortunately im having trouble finding an ej20t. i've looked everywhere that i know of thats local (save shipping costs) i can get an import but the shipping costs more than the half cut itself!! cheers
maybe do ya HGs on your ej22, drive it, and wait for a ej20turbo to pop up, thats if youre really that unhappy with the ej22s performance, they do go pretty hard
