My Vortex Project
Remove the back seat then lift the board/shelf upwards.. it has some plastic pop clips so be careful. I use a long flathead screwdriver and lever it up.
If Vortex is like L Serie sedans there will screws or bolts at the base of seat bit you sit on, either side of hump and out a bit, undo them, flip up and out the seat base and see if there is a way to remove seat backs a bit to release parcel shelf, may need a bend in the guts to clear each end of trim etc
Thanks for the info guys, yer sounds like fun lol, yer the interior is completely out expect that rear seat, (had to remove it cos the sun roof has a leak and not sure how to fix that yet, but I'll deferentially give that a shot, just have to remember when I take out the bolts i gotta keep them labeled so i know where they go back. After I take out the rear shelf and fix it up is it easy to put back in?
As for the bad news H-Top there's a lot more coming after this is done lol
Johnny T
88kw of fun waiting to happen
Johnny T
Bolts
To save loosing bolts or not being sure where they belong I generally put them back in the hole after taking out whatever they secured.
Hylton:twisted:
Ps I know it is more work but a lot quicker than trying to find them later.
Hylton:twisted:
Yer thats a good idea olddog, i'll defently remember that
well long story short, couldn't take out the rear passel self cos my car was drenched in the inside because the sunroof leaked and rear interior (there just behind the doors), so now i got another problem on my hands, so just a quick question for everyone out there, how do i fix the leak in the sunroof and rear interior leaks.
Thanks for the help again guys, i really appreciate it and sorry to ask a lot of questions again and again :P
Johnny T
Johnny T
water water everywhere
hi
Take out the sun roof, there are 4 holes, one in each corner you need to blow them out,
They have tubes that lead to the bottom of the car and are the main reason they start leaking, you can get replacement frames but they are expensive. you can take out and repair the frame but its a big job. i will post some pics tomorrow.
Cheers Pete
Cheers Pete
Use The Fork Luke
Thanks coupe, yer no rush on the info
i wont have time this weekend to do it, but i'll get a tarp to a temp fix, i'll take some photo's a.s.ap where the other leaks are comming from, but I'm not 100% sure if its caused from the sun roof, but hopefully when i get some photos they would explain a bit more (I hope)
Thanks again for the advice
Johnny T
Johnny T
pics
here are the pics of the sun roof, you can see the tubes that are the start of the problem.
the gullies are badly shaped then they pool the water which starts the rusting. the whole frame is only bonded in with salastic, you can heat it up and using a scrapper and a heat gun you will get it out.
- sunroof 2.jpg (88.46 KiB) Viewed 15136 times
- sunroof 1.jpg (88.46 KiB) Viewed 15142 times
Use The Fork Luke
link
Try this link to a XT thread about the sun roof
http://subaruxt.com/forum/viewtopic.php ... t=sun+roof
Use The Fork Luke
Bad news everyone, I took off the sun roof off yesterday and found a f load of rust threw the roof, if it was a little bit of rust it would of been ok to fix, i'll upload a photo of what i found when i can.
So basicly I am going to take off the panels and all the good parts off my vortex and keep them as spare parts and hopefully find a new vortex and put them on there.
Also I want to say thanks to everyone for the help on this car but unfortunetly wont be able to get this one running.
Johnny T
Johnny T
Johnny T
Johnny T
