whats the secret....?
trying to pull the steering wheel off my mates 89 touring wagon and having no luck.. basically we got to the point of attaching it with chains and shackles to the back of my mum car to see if we could "tow" it off, so im pretty desperate is there a bolt or something in them that we're forgetting about or whats peoples suggestions as to how to get it off... cheers.
to do list:
to do list:
- subarooster
Usually just the nut in the centre of the wheel, then hold the wheel at 9 and 3 o'clock and give it a good rhythmic tug either way.. (note: this may take a minute or so)
01' Liberty B4.
although "rythmic tugging" is usually a winner with me its failed this time... this wheel is proper stuck.
to do list:
to do list:
- littlewhiteute
- d_generate
there should be 2 holes either side of the center bolt, get a piece of flat bar & drill holes the same distance apart then get 2 bolts 12 or 14mm & wind them in a bit at a time & it'll pop off.
Excuse the crude drawing
- littlewhiteute
Yes I have whacked myself in the face with a wheel.
It tends to hurt !!!
I know about collapsible steering columns etc but in desperation in the past I have loosened and left on the column nut (this was after I had hit myself in the face - you usually only do this once), put both knees up behind the wheel, keep a constant and heavy pressure with my knees and VERY gently tapped the end of the column shaft with a copper dolly or a piece of wood. Not the best for the column but it worked.
LOLZ.. I bet you learn pretty fast to leave the nut on by a couple of threads
I've found by sitting on the drivers seat, loosen the column nut and then hitting the 9 and 3 points with closed fists (base of the clinched fists) for about 8 to 10 times (does make some sore hands but nothing bad) each side then pulling the wheel towards you and when it comes free, then remove nut and all is good.
- sven '2'
If everything fails, the steering column is surprising easy to cut with a hacksaw.
Used this ape-like method (which is probably not applicable on this job) on a wreck to salvage the tasty indicator stalk with pristine lettering.
Goodluck!
Goodluck!
