DCCD RWD conversion
H-top
DCCD RWD conversion
Post by H-top » Fri Jan 28, 2011 6:13 pm
G'day,
if I set me DCCD to full lock and remove my
front shafts, it cope in RWD for very long?
Only about 200hp
cheers,
Samuel
H-Top
rolling in
spike
Post by spike » Fri Jan 28, 2011 8:00 pm
what are we expecting to cope?
and what are you planning to do?
we went drifting in one last year, not sure on the specs though was just a wrx and that held out fine with 250 or about that had the replaced front diff thingy though
H-top
Post by H-top » Fri Jan 28, 2011 8:32 pm
The centre diff.
Track Drifting is the plan.
Fingers crossed
H-Top
rolling in
Post by Gannon » Fri Jan 28, 2011 9:51 pm
Nope
The DCCD uses a multiplate clutch to lock the speeds of the front and rear output shafts (of the planetary centre diff) The diff still handles the brunt of the torque, the clutches just help.
Removing the front driveshafts will only destroy a perfectly good DCCD differential.
brumbyrunner
Post by brumbyrunner » Sat Jan 29, 2011 7:02 am
Use a spool in the centre diff instead. Easy to install in the car, the gearbox doesn't have to be removed.
Make sure you're rear LSD is in good nick too.
Settlement Creek Racing
H-top
Post by H-top » Sat Jan 29, 2011 7:04 am
Roger.
Will look into a ppg spool and a plated R180 rear end
H-Top
rolling in
Post by Gannon » Sat Jan 29, 2011 4:08 pm
You should give your DCCD to me, i'll cover postage ;)
H-top
Post by H-top » Sat Jan 29, 2011 5:33 pm
Why? It's only an STi RA V-series DCCD lol
the controller is great, DCCDPRO.
H-Top
rolling in
Post by Gannon » Sat Jan 29, 2011 5:43 pm
Yeah they are worth chips, common as.
You will probably have problems giving it away ;)
H-top
Post by H-top » Sun Jan 30, 2011 11:19 am
Yeah the wreckers were
going to give me 2 half bald
miss-matched tyres
H-Top
rolling in
