L'series Clutch Kit
FujiFan
L'series Clutch Kit
Post by FujiFan » Thu Jan 06, 2011 9:43 pm
Hi everybody
Will need a new clutch ASSY when i get round to upgrading gearboxes soon. What brand recommended and whos good to fit and balance whole ASSY. Also has anyone got a EA82 Flywheel surplus to their requirements? I would like to get everything ready for the "weekend project" in advance. Your advice/help is greatly rewarded, possibly in the afterlife.. ;)
Jayman
Post by steptoe » Fri Jan 07, 2011 12:16 am
what upgrade are you doing? L series five speed into MY? If so and you have eight inch clutch 200mm you can keep flywheel and pressure plate and use petrol gemini rwd 1.6 l clutch disc. Or are you upgrade from auto to manual?
FujiFan
Post by FujiFan » Fri Jan 07, 2011 10:52 am
Going from P/T 4wd to F/T, since gearbox is coming out should replace original clutch ASSY at same time I figure. Looking at H/duty upgrade for clutch.
H-top
Post by H-top » Fri Jan 07, 2011 11:11 am
Excedy to a HD clutch. $300 from memory
H-Top
rolling in
FujiFan
Post by FujiFan » Fri Jan 07, 2011 11:35 am
Thanks Sam will make some calls. Reason looking for spare flywheel is to have it machined and a kilo or 2 taken out. then have whole clutch/flywheel ASSY balanced, ready to fit minimising down time..
H-top
Post by H-top » Fri Jan 07, 2011 1:30 pm
I've got a spare
H-Top
rolling in
FujiFan
Post by FujiFan » Fri Jan 07, 2011 10:40 pm
Sounds great, I'll take it Sam. :cool:
