A little treat for Brumby lovers
Reading through an oldish (read: no posted on for a while) thread I thought I'd add some stuff that I think I know to the following:
Sweet brumby too! Super low k's!!! How many has it got now? I once managed 100k kms in just over 12 months. Crazy days! Now I'm averaging between 40 and 50k kms...
I believe these little numbers are indicators to say not to go further than the indicated speed in the gear number shown in the little circle. I did this in Sunnie the Brumby before we swapped the dash and I can tell you they sound like they are revving VERY hard! I've not compared with the tacho since installing it... Something to do one daysomeguy wrote:Whats the tiny 1 2 and 3 on the speedo for?
Is it to indicate what gear you should be in at certain speeds?
Because 40 in first gear seems a little extreme hehe, my L Series 5 speed starts to make a whining noise (only in first and reverse) after 20km/h - 2000RPM let alone 40km/h (don't think I have ever gone past 25 in first)
Hope you've got this sorted already, if not here's the fix: On the passenger's side of the heater box the cable from this heater control lever meets with a geared plastic thing that then operates another cable (and the heater core air duct flap) that operates the heater core's tap to allow hot water to flow through the core for your heater...phantomD wrote:On a side note, my heater control no longer clicks and is not moving properly since install, is that something easy to fix?
Back again to dangle a carrot...there are some BIG plans for this car at the end of this year. I'm tossing up whether or not to do a write up...I will definitely post some pictures on here anyway. It will be very exciting to drive when everything is done...which may take a few months.
Holy credit card debt Batman!
C'mon fess up -what are you planning??
Giles.
Giles.
Hey I got a little button like that in my cab !! hehe Good to go for your comin' summer eh? Sort of lights up in the dark when I've got the lights on - class!phantomD wrote:Can anybody spot the difference?
Giles.
Giles.
- FROG
yep and the spare wheel has been rotated by a couple of degreessteptoe wrote: The AC is missing in the forst shot ?
I'm not saying just yet!! Certainly you may get the idea from a few threads that will pop up around the place in the next little while.1111giles wrote:C'mon fess up -what are you planning??
Yes I thought the backlit A/C button was a nice touch too.1111giles wrote:Hey I got a little button like that in my cab !! hehe Good to go for your comin' summer eh? Sort of lights up in the dark when I've got the lights on - class!
This is turning into a real case of "spot the difference"!! Even I didn't notice that, haha. Thanks for your help with those stickers by the way.FROG wrote:yep and the spare wheel has been rotated by a couple of degrees
- FROG
Yep yep bring on the pics
Nothing like a bit of suspense to get us going
- littlewhiteute
