L series Air / Fuel Ratio
I finally got around to doing a fuel economy test on my L series.
Turns out it used 42 Lt to do 358 k's , so that equates to nearly 12 Lt per 100k's
Thats all city driving, but going easy on the pedal. Pretty poor economy from what I gather. Ive used the engine cleaning spray, replaced the air cleaner, plugs ... Next thing would be to check the Air / Fuel Ratio ?
Can someone tell me the process to check and adjust the Air / Fuel Ratio on a carbied motor ( ea82 in a 94 L series )
Thanks
Thanks
![Image](http://i287.photobucket.com/albums/ll148/aptitudex/sig2.jpg)
Thats actually pretty good for a carbed EA82
You have to remember it's a fairly small engine in quite a large car, it has to work hard to do little tasks
mine averages 12.5/100k with the fuel/air ratio correctly set, serviced every 5k, new leads, distributor, new coil, filters etc etc.
Well with my 92' wagon I get about 11 L/100km city cycle, consistantly. Mind you I have recently overhauled the carby which included re-bushing the throttle plate shaft so there is no undue play. Custom exhaust system (Engine pipes right through, 2" Cat etc) + the stuff you mentioned in your tune up. As for checking the A/F ratio (I've had a standard 18.5mm bung fitted to engine pipes for a EGO sensor), Needs to be done at tail pipe. Plus subaru put a plug over idle mixture screw from factory (So not to degrade Catalytic Converters job). You can drill out this plug BUT check mixture output first at decent workshop before screwing around (Pun intended) with idle mixture screw. Oh and by the way its a bit difficult sometimes to resist using the right foot to hear the music these things make with a new exhuast system
Bit unfair on the carby with all the fuel quality changes taken place since they were built. I do about 12 per hundred on LPG in my turbo L so I am stoked when I compare to your petrol figures. You'd really need to find a workshop that can do exhaust analysed ratio and be able to rejet the carby if necessary as that is how most of it would be changed. Pain in the arse that would be with the hitachi , sourcing and changing jets and reassemble to check etc.....
Gees the mpfi turbo was pretty good on fuel then ????
Best I can get with a carbied 91 L series is 10l/100km on the highway and a corresponding drop around town of a couple of kays per 100 litres.Sounds about right to me.
Suby Newbie
Suby Newbie
I had an EJ22 in my previous gen 2 libsteptoe wrote:and when you answer this allow for any discrepancy of the odometer too please.
Still to hear of any EJer that wants their EA variant back !!
And an EA82 in my current L
I am one of the crazies who prefers the EA
But that's just because I am a carburetor enthusiast, I am sure if I drove a carbed EJ I would love it but I am yet to find one.
Really if you're looking for economy from an EJ it just isn't going to happen. When you put your foot on the accelerator pedal you actually go somewhere - then you find your foot going further in, thus resulting in going somewhere fasterPunisher wrote:What economy are people getting out of EJ's in an L series ?
![Twisted Evil :twisted:](./images/smilies/icon_twisted.gif)
Seriously though, the EJ - the EJ22 gen1 series uses a little more fuel than the EA82 MPFI but would still be doing better than you're getting now. This is also with a three inch lift - higher body = more wind resistance, its also got a rear bar with a jerry can thus more weight to move around too. Overall I'm happy with it.
After the EJ conversion the next best thing I did was shove a 2 and a 1/4 inch cat back exhaust system. Very Noice!
Once you go EJ - you don't go back to EA, unless its in another subi that will be EJ'd shortly after you take possession of it
