Amazing what a tune can do!
78sti
Post by 78sti » Wed Nov 03, 2010 10:30 am
I had my cay dyno tuned yesterday.
It only took 8 years to get around to it (actually missfire problems forced me into it)
I am impressed with the results 210.9 kw at the wheels @ 18psi
Not bad for a 32 year old ute:mrgreen:
It is now running a v3/4 gt forester engine alutronic ecu and 750cc injectors, and td05/06 turbo Everything else is pretty much stock.
78sti dyno-001.jpg (35.83 KiB) Viewed 2220 times
H-top
Post by H-top » Wed Nov 03, 2010 10:42 am
respect
H-Top
rolling in
Post by Alex » Wed Nov 03, 2010 10:52 am
respect x a billion.
nice power :)
Chrus
Post by Chrus » Wed Nov 03, 2010 11:44 am
not a bad curve - though photos of tyre smoke dont seem to be loading ;)
MY05 WRX STI Spec C Type Ra
MY05 Legacy Outback LLBean
89 Legacy RS Turbo
Captain Obvious
Post by Captain Obvious » Wed Nov 03, 2010 9:00 pm
nice one 78!!!
chridk
Post by chridk » Thu Nov 04, 2010 7:51 am
210 kw in a car that would be lucky to weigh 1000kg ringing wet, sound like alot of fun. I used pass your ute in the street when I was a postie in clayfield (i would always take a personal moment to drool if it was there). Your ute is one of my inspirations to get mine finnished.
Cheers Chridk
Post by guyph_01 » Thu Nov 04, 2010 11:39 am
impressive. What ECU does you car have? is it factory or after market?
Thinking of getting the RS tuned too:)
78sti
Post by 78sti » Thu Nov 04, 2010 1:34 pm
Gee I haven’t worked at Clayfield for 3 years, Amazing how time flys!
The ecu is an Aultronic PNP with the forester harness and no AFM. Great ecu but if I did it again I would use an Aultronic SM4 and wire the harness direct to the engine.
I am going to do a power steering conversion next. Should be interesting as I am also increrasing the roll centre in the front to try to imporve handling some more.(changing the mounting point of the lower control arms and adjustable tie rod ends for bump steer)
Eventually when I can afford the time and money it I am going to do a rear coilover conversion with adjustable camber toe and roll centre.
