I'll be ripping the heads off my L series next week hopefully. (Finally!)
The previous owner said he used monotorque gaskets when he installed the "new" motor not long ago. Reckoned he pulled off the heads for inspection to check for cracks and replaced the timing belts, oil pump, etc while he was at it.
When I received the vehicle, exhaust was pressurising the coolant and blowing it into the overflow tank. I am getting water in the exhaust also. Only getting occasional slow large bubbles once the thermostat opens.
He claims he never had it run hot so I'm hoping it is only the gasket and not cracked heads. I have a replacement set of heads on the way which I will recondition prior to pulling the motor just in case mine are buggered. (Have a spare motor with cracked heads which my old ones will go on if they test OK
I guess I'm wondering why the gaskets he fitted would have failed?
Has anyone else here used them, and did it work well?
Any thoughts about this apparent head gasket leak would be appreciated also.
