Head Gasket on brumby
longy99gt
Post by longy99gt » Mon Jul 12, 2010 12:16 am
hey guys, need to replace the head gasket on the brumby???
best suggestions as to where i can get one from??
DIY job or take it to my specialist?
costs???
"SUUBMARINE"
20" LED Front Light Bar
Post by steptoe » Mon Jul 12, 2010 12:27 am
Permaseal brand one torque technology http://www.aagaskets.com.au list local suppliers on their site as well as part number. Two heads of course. Do it yerself is easier if motor is out, struggle a bit more insitu esp if head studs stuck to head with corrosion build up, get heads done too or checked at least while off
Post by AlpineRaven » Mon Jul 12, 2010 8:20 am
You can do it yourself if you know what you're doing, get the torque & torque sequence correct while tightening it up. It is lot easier to get the engine out to do the job there - can be done while engine is in, but lot easier if you take it out.
Post by RSR 555 » Mon Jul 12, 2010 9:32 am
Hey Longy, Grab yourself a Valve Regrind Kit from Veales and borrow a Gregorys Manual from the library or I have one if you need. I do it myself but I've done many over the years. Are you looking to do it before you leave?
Matt
Post by Matt » Mon Jul 12, 2010 5:13 pm
Check out this link for a coy of the online manual. It will give you an idea of what your in for, it is relatively easy with the only special tools is a Torque wrench.
http://68.178.49.203/jon/SubaruEA81-ServiceManual.zip
"Claudia"
