Interested in what's available down under
Suparu,
You can get the L series AWD box with lockable centre diff - yes its the most desired way to go, but they're hard to find in oz. In the US they should be easier - just find an RXII coupe that hasn't had the gearbox swapped, easier said than done if the owner knows what they're sitting on.
You'll still need to source the L's good low range and the 4.11 or 4.44 ratio diff that you want. A cut and shut will be required on the pinion shaft as the L's one is longer than the EJ's one, the L's AWD one only comes in 3.7 or 3.9 - I believe the 3.7 is more common than the 3.9...
I'm in the process of building this box myself for Ruby Scoo. She'll be awesome once its done. Just need a few parts and some time!
And again, I'm still yet to see an EJ AWD with locking centre diff factory fitted...
I'm still 99% sure there isnt locking centre diff from factory for EJ series, havent seen in the books or manuals.. The only information Ive seen is L series era.El_Freddo wrote:Suparu,
hmmm
So, as I kind of suspected when starting this inquiry, to get what i want will require 2-3 transmissions (at least one from Down Under) fairly significant know-how, some money outlay and TIME...
It sounds like the easiest way to get a good final drive and a low range in a FT AWD 5 speed is an australian forester box, end of story. If i were so inspired, I could then open it up and swap its 1.44:1 for an EA82 (L series) 1.59:1. but that'd take another tranny and a lot more info at hand (thanks alpineraven, you've got that dialed, AND posted!!) ...
Locking center diff, full time AWD, dual range, blah blah blah... the stuff dreams are made of (unless you're phizenza and can make it happen
), is certainly WAY beyond my means and knowledge, ooh and parts availability... Not a decent junk yard for 4.5 hours from Moab!
I think i'll try to stick with that plan:
get a good used Aussie fozzie box, D/R FT AWD 1.44:1 low, and bolt it right up to my USA EJ22.
plug-and-play as they say
and if this is TOO problematic/costly, i may just do an outback auto tranny swap, but that'll be another box or questions, to be sure....
so, again, to start trying to get a good used forester transmission
from someone down there...
Ooh this modifying is such a road to travel
suparu wrote:hmmm
Locking center diff, full time AWD, dual range, blah blah blah... the stuff dreams are made of (unless you're phizenza and can make it happen), is certainly WAY beyond my means and knowledge, ooh and parts availability... Not a decent junk yard for 4.5 hours from Moab!
can admin conferm the origin of this user ?
Hey Seagull,
Sorry to raise suspicions but you are wise (especially this day and age and on the internet) to be cautious. I realize I'm new to this thread (as well as offroadsubarus.com) but I have been around other subaru forums for a while (namely USMB for going on 6 years).
I'm in the USA and here we do not have dual range AWD transmissions like you good folks down under. I've been researching this option (ask phizinza) for a couple years now, and think i have a good idea on the best and hopefully least costly way of getting an ej series bolt-on tranny that is dual range full time AWD.
Thanks,
-mark-
Thanks,
-mark-
What way would that be?suparu wrote:Hey Seagull,
Thanks,
-mark-
AlpineRaven wrote:What way would that be?
Yeah exactly!
In my dreaming and hoping world (which I'm trying to figure out how to make into my real world) I think the least costly way might be a fozzie box (tranny #1, and of story), rather than a liberty box (alternate tranny #1) which would be cheaper from the yard, but same in shipping then cracking it open to make it 4.11 (from parts out of tranny #2, probably USA OB 5MT) and give it a better low gear from a USA EA82 dual range (from parts out of tranny #3).
Not to mention the time and frustration savings
The first time I read the dictionary, I thought it was a book about everything.
-S. Wright-
If at first you don't succeed, rev harder!
-S. Wright-
Fair enough mate...suparu wrote:
Yeah exactly!
the bar across the top of the forum (User CP, FAQ, Members List, Calendar etc) has a "Classifieds" button.
click it and follow the instructions.
You have to be a paid member.
EZ30 L series - Monsterwagon
That must be the key...AndrewT wrote:the bar across the top of the forum (User CP, FAQ, Members List, Calendar etc) has a "Classifieds" button.
>>You have to be a paid member<<.
I thought I donated here, I guess I must not have
Thanks friend.
-mw-
-S. Wright-
-S. Wright-
Throwing feelers out for a good used dual range, 5MT from an Australian forester.
looking for 4.11 final drive axle ratio and a 1.44:1 low gear.
(i still need to make my donation, then I'll post up in the classifieds
thanks,
-mark-
thanks,
-mark-
-S. Wright-
-S. Wright-
I have a RUNNING gen 1 EA71 1980 BRAT with an extra motor and some parts (like a windsield and gen 1 subaru factory winch-mount tube bumper) to TRADE for a good used gen 1 forester dual range AWD Aussie gear box. . .
-S. Wright-
-S. Wright-
Looks like 04FXT had 4.44 final drive but no low range (as some had indicated) and 03-04 NA foresters have 4.11 FD with a 1.196:1 low gear... In light of this info, it seems a fozzy box is better, then mod it to have the EA low gear...
http://www.subaruforester.org/vbulle...03-04-a-34149/
Now totrack down this illustrious 4.44 FD 1.44:1 low I've heard about...
-S. Wright-
-S. Wright-
True that - but since finding out about the L locking centre AWD gearbox I've wanted one. Now I've got one in the shed, plus a donor EJ box (finally) and a standard L box (broken 4wd engaging mechanism) for a build. SO cannot wait to get home to build that box!suparu wrote:Locking center diff, full time AWD, dual range, blah blah blah... the stuff dreams are made of (unless you're phizenza and can make it happen)
All it takes is time Suparu. Relax, talk about it to work out exactly what you need for the desired gearbox. Then keep an eye open as you cruise around, you'll be surprised what you find and where you'll find it. I've always had a budget - as cheap as possible - it usually works out well. 50% off at the Pick a part wreckers helped out a lot! Right place at the right time - you can't plan that!
I say this as I've just read back through your thread realising you've got some blinding enthusiasm going on there. Have you looked around enough in the US to find a dual range EJ gearbox from an early Liberty at least? From my understanding the US got the early libertys with dual range. I could be completely wrong there though, it wouldn't be the first time!
All the best with it, just take your time
Hey Bennie, Thanks for the props and beta.. i'm psyched for you project. I've chatted with Phizinza a bit and he was my first and strongest lead for info and potential for parts. He's good people!El_Freddo wrote:All it takes is time Suparu. Relax, talk about it to work out exactly what you need for the desired gearbox. Then keep an eye open as you cruise around, you'll be surprised what you find and where you'll find it. I've always had a budget - as cheap as possible - it usually works out well. 50% off at the Pick a part wreckers helped out a lot! Right place at the right time - you can't plan that!
Yea, I know patience... But its not a strength when I get fired up on something
But you are right... I do have a contact here that's willing to work with me on sourcing one, now to just narrow down exactly what that is...
I'm getting there, and with a recent email from Michale at Scorpion, I think I'm about there...
He verified (as did Point just now) that the first AUS Gen Fozzies (97-2002) came with 4.11 FD and 1.44:1 low. Other sources (and Miachel) show 003-04 (and newer) with 4.11 FD and 1.196:1 low.. i know the EA mod to get the 1.59:1 low, but with a first gen 1.44:1 is not bad, not bad at all..
And the US did not get dual range AWD boxes. This is actually the first I'd hear of an possibility we did
I saw one AUS liberty float around the U.S on USMB (Zap originally got it from someone here), but that's 3.90 Final and 1.196:1 low... too much work to make it what I'd prefer it to be...
I am getting there though, narrowing my thoughts vs. what exists, and I appreciate all you folks' help with my research and formulating this project.
And you are certainly right about the patience part
Roger that Point,Point wrote:I pulled apart a gearbox today out of a '99 SF Forrie to confirm ratios. 8 bolt bellhousing, 4.11 final and 1.447 low range reduction. I assume that the '97/'98 (4 bolt bellhousing) is the same. Unfortunately this one has been full of salt water and isn't much good anymore....
Michael at scorpion just verified my gearing suspissions on AUS fozzy gearboxes...
He replied as such, "Hi Mark. Your research is correct. The first model Forester (S10 97-02) with the 2.0 non Turbo engine (EJ20J and EJ202) had the 4.11 FD and 1.447:1 Low Range reduction. You can fit a 4.444:1 Crown wheel and Pinion to this but the outside edge of the Crown wheel teeth need to linished down to clear the Low range gear. You can also fit our Lower ratio set to this as well. The same applies to the later Transmission from the S11 which has the 2.5 Engine (no Turbo models have Dual Range), the only draw back is the std Low range is only 1.196:1.
All Boxes have a sticker on the left side of the Bell-housing with a code beginning with TY. An example of the early DR box with the lower ratio Low Range and 4.11 FD is TY 755XS2AA
Hope this helps, if you have any other questions feel free to ask."
So I think I'm narrowed to a gen one (and with your input on the 4-bolt housing, as is in my legacy) I should stick to a 97-98. BUT the 8-bolt (as I understand) fite fine, just a few extra holes not doing anything...
Thanks again dood!
Good times here lots of good info and help!
-mark-
-S. Wright-
-S. Wright-
You still can mount 8 bolt gearboxes on early engines.Point wrote:I pulled apart a gearbox today out of a '99 SF Forrie to confirm ratios. 8 bolt bellhousing, 4.11 final and 1.447 low range reduction. I assume that the '97/'98 (4 bolt bellhousing) is the same. Unfortunately this one has been full of salt water and isn't much good anymore....
So I have someone Down Under helping me with a gen 1 Forester gear box, but now I'll have a couple more questions before I really get into this project.
my '95 legacy 5MT with 3.90 FD is a cable-actuated push clutch.
Is a gen 1 AUDM forester a push clutch or pull clutch and is it a cable or hydraulically actuated clutch?
thanks,
-mark-
PS, thanks for helping me on this project Spike!
thanks,
-mark-
-S. Wright-
-S. Wright-
